in lahore this oil is not available yet according to a lube shop it will come on 15 june
secondly i want to change engine oil of my car which oil filter should i use with helix ultra
dont use shell,its useless,try micking fully synthetic,im using that n pretty satisfied with it
jz i changed the engine oil before reading your post, helix ultra 5w40 seems to be a good oil
use genuine honda oil filter n change at 7k if u r using shell helix ultra fully synthetic
can v used synthetic oil in old cars ?
depends how old your car is? if engine is in good shape then you can use
i ve used genuine oil filter
i m asking generally whts da effect of using it in old engines? ie more then 100k driven ! btw mine is 54 k driven
i dont know much about that........oil seals may leak and engine may decrease oil if lower viscosity is used you can use in a 54k driven car
my experience with shell isnt that good im pretty satisfied with the oil i got this time,might go for mobile 1 as thats a better option
m gonna use this caltex fully synthetic next time to compare with shell helix ultra.....the best i like fully synthetic is liqui moly until now which m using on markx
what is the price of liqui moly 4ltr pack?
i think 4200rs....i dont remember the exact price
Reborn 4.5 ltrs - no way it requires only 3.7ltrs bro, check manual.
tht wat i told the mechanic....they said 4.3liters of engine oil wit oil filter...plus they showed me wen fill up of 4 liters the stick was showing lil less than full....strange then i had to buy 1 liter more :S
Best way is check the owner manual. It mention in oil section about quantity. If ur vehicle is consuming oil than check any leakage or one most important cause is oil is Fake.
Is the new havoline 5w40 ACEA A3 and is it suitable to replace it with 5w30
How about the old 5w-30 its discontinued or still being sold by Caltex
