ok, i will on upcoming oil change and service
Recently bought this. Automatic SX 8 2002.
Noticed any difference after changing fuel filter and oil?
Fuel filter change krne kay baad avg per farq para tha in my city.
Without AC 11 with AC 9
What kmpl you are getting
11 to 12 KMPL in Pindi Islamabad. Did not check on Highway. But I did few changes to fix average before it was giving around 7 to 8.
i need some help sourcing some parts for a honda city 1998 automatic transmission conversion and currently cant find these, if anyone can be of some help, I am currently in Islamabad and these are the parts needed as told by the mechaniccontact me at 03335392333
The changes you wrote above?
What you did? And 11-12 with AC or without it
Without AC.Replaced gear oilReplacing engine oil to 10w40Cleaned TBSet TPS to 0.48V it was 0.80v before Replaced fuel injectors found ones from same engineReplaced fuel filter. Replaced plugs to iridium denso VK 16Replaced Plug cables.Set tappets. Set kickdown cable to have some free play before it was tight.
I am having problem with gear, it is not shifting to 2Any hints? What i should check
HELLO SALMAN ,CAN YOU SHARE IT ON jibran715@gmail.com
Aoa sir can you plz send that manual on saeedsajid2002@gmail.com maine apni gari ma p2j-j62 ecu ke saath swap huya tha d15b3...maine nae karaya hua wa tha...is manual ki maddad se ecu ko trick krna hai ke ecu ke saath tcm laga hua hai kunke ma transmission stock d13 hypervalve ke saath jo 5 speed transmission ata wo laga hua hai
Also email me sx8 manual
Please email me alihumza1612@gmail.com
but bro...in 2002 there were no such thing like CVT transmission and guys are using Honda ATF DW-1 in Philippines.
Greeting, It took me a while to come up to Pakwheels and saw your thread. I was looking for User Manual of the Honda City Exis. Can you please share it on noyantajik@gmail.com? Ill be grateful.Regards
