Hello guys I also have a Navy problem but with rolla I have Toyota corolla pkdm OEM head unit but no SD card if any body can tell me a solution company is asking 18000/-
Sent from my A900 using PW Forums mobile app
Please PM your contact no
Download the update tool from given below linkhttps://www.naviextras.com/shop/portal/downloadsPull out your map card from GPS slot & insert in card reader, press update Save 2500 for sure
Need assistance ??? Send your contact no via PM and wait for my call
^will definately try it.
when was the latest update for city's oem nav system released?
Thanks for sharing the download link, however, after downloading and installing the naviextras toolbox it dosent seem to recognize the memory card from the card reader...I have tried many things....let me know whether their is some solution(if any).....
great help bro, took backup of my card, updated the MAP, POIs, landmarks etc.
the data the card has was of 2006 and the updates available are of Q1 2013.
i have not yet checked it in my car, will do it in the morning
Bhai please tell whether working or not??
Sent from my Galaxy Nexus using Xparent Blue Tapatalk 2
yaar i successfully took the back of my card but havent tried copying it on another card for testing. dont have a backup card i will do that whenever i get time but as long as updates are concern maps updated and working perfectly fine with more details.
please let us know whether the upgrade works or not. I have the Q1 2013 upgrade
i inserted my Navigation SD card in the laptop SD Card slot, and run this software but it says
NO device is connected.
how to proceed ?
^Check if your SD card is unlocked, it has a little sliding tab on the left side.
no, its not locked.
it still doesn't recognise it.
I can see the folders and files by viewing the through file explorer.
same issue here.the navigation sd card doesnt seem to be recognized by the software.though easily recognized by computer. @irfansiddique please let us know how you managed to do this.
it was quite simple guys, do one thing first turn on the software than insert the card.. looks like a card reader problem . . can you see your sd card in My computer ?
Yes, I can see my SD card on my explorer. I can copy the files.
I have turned on the software then inserted the SD CardDID Not work
I have inserted the SD Card then turned on the softwareDid NOT work
its actually quite weird . in my case it was just plug n play. try changing the SD card or try doing the activity on some other computer if possible. . . .
