want to do the following work after a long time in my santro.
1: brake service and checking
can be done by any road side mechanic no tech involved and replace pads if necessary
2: one door lock motor wire broken
if i were you i might have gone for a diy instead of going to any electrician who will tear the things apart fixing that wire
4: Engine oil and filters changing
routine work no tech required
5: noise is coming from AC compressor when it is ON will go for its adjustment and may be changing the drier as recommended by AC tech. what is your opinion the noise could be from some moving part like bearing?
More info on the noise is required, in my car i observe a little shrilling noise on a certain rpm but not after that, if thats not the case and there is a continuous humming sound it must be the compressor Bearing, get it replaced by a good technician, if you were in lahore i might have referred to some one since thats not the case so excuse me..
6:door hings/latches adjustment, or may be replacement as my car's doors giving some noises, though no play in the doors not even slightly up-down play.
Try washing them with WD-40 and then lubricating/ Greasing them, will surely solve the problem as you mentioned no play in the doors.
7: All sensors cleaning, from where in Islamabad/Rwp? please suggest.
Go for a tuning only from and hyundai 3s, they will do the job.
8: door side molding near window glasses along the door horizontally. shown in picture
Again if i were you i,ll never go for any such thing, it looks cheap to me but thats just me, and its mostly installed by elfy which will f__K your paint when removed
9: the metal supports for the rear bumper is broken and need to be weld or replacement, should i go for weld or new is recommended?
You should go for weld, btw mine are broken too but Im too lazy to get them done..
10: want to check all the bushes from some mechanic, as the car's front wheels does tuddd tuddd noise over bumps and speed breakers.
The things you might need to check for the sound you have mentioned are shocks, ends i.e ball joint, balance rod bushes.
11: on the long term i want facing of flywheel as one mechanic told me that your car engine's RPM goes high but the speed remain the same slightly because he thinks that the clutch is sleeping a little, i don't feel so, but he is right in one thing that when i was changing my clutch the mechanic didn't machine the flywheel and install the new clutch, this is his point, may be right, but the observation of more struggling engine with respect to its speed is evident even by me some time ago, but may be i am used to it now so feeling not a big problem.
No info on that but the best way to check this issue is to climb on a steep road.
now please tell me a good mechanic in RWP/ISB specially for sensors cleaning, because i don't want any mechanic to experiment on my car to learn how to clean sensors, i can do that myself as well.
Goto Hyundai 3S for sensors and no one else.
required addresses and contact of the following personals with good reputation in the twin cities.
1: AC technician
2: mechanic
3: electrician
i myself didn't find any good mechanic till now, the one i found long time ago is gone to Korea,
PS: Please bear with me for such a long post, thanks:P
[/QUOTE]
