Allhumdolillah came back from Naran safely.
Here is the summary.
Traveled from Islamabad to Kiwi (Stayed in Faisal Hotel). Next day traveled to shogran and Siri Paye via Jeep. My mehran was not able to go till Shogran due to 4 passengers + luggage.
Next Day Went to Naran. That place was not very crowded. stayed 2 Nights in Palace Hotel in PKR 1000 / Day.
Upon reaching Naran there was radiator coolant leakage from my Mehran near engine side. I filled the radiator with water and again it was emptied in 1 minute.
After searching about 1 hour found a mechanic he said to come in morning. Next day his number was off and his workshop was also closed.
A local guy checked the car and said that there will be a mechanic near PSO petrol pump in Naran. You should visit his workshop. I went there and found a mechanis named "Safdar". He inspected the car and said that Water Body is leaked.
He opened the timing belt portion and found a hole in water body. I left the car to mechanic and went to Saif Ul Malook with family. Upon coming back around Maghrab time i went to mechanic. He said that I repaired the water body and filled the hole. He filled the radiator with water and when I started the engine once again water was leaked and radiator was empty.
He said "ye phir kaisy leak ho gaye"
Then he said I have to order new Water Body from Balakot and due to Muharam all shops are closed in Balakot.
In Naran there is only 1 auto part shop near Bypass "Naeem Autos". you go and check for water body from him.
The guy at auto part shop asked 3000 for Mehran Water body of GMB company. After little bargaining he gave me that Water body in 2500 Rs. The shopkeeper said "Naran walon ko kuch tu faida ho na"
Came back to Mechanic and asked him to replace with new waterbody. meanwhile he repaired the old one by pasting magic depoxy on hole.
So he replaced the new one and I gifted him old water body. Mechanic took 1500 as labor
So replacement of waterbody took 1 day and 4000 Rs.
Thanks that I got it from Naran and mechanic was also available.
On next day I started journey from Naram around 10 AM and reached back to Islamabad around 7 PM
