Salam guys. With a bit of a workup, Ive been able to come up with this simplified maintenance schedule for all Vezel owners. [U]
Maintenance Schedule[/U]
Engine Oil and Oil Filter
Change every 5000-6000 km
Engine Oil and Coolant
Check at every fuel stop
Recommended Fuel
HOBC/Regular unleaded ? 70/30
20000km/12months
? Change air filter
? Lubricate all hinges, locks and latches
? Rotate tires (Check tires inflation and condition at least once a month)
? Inspect front and rear brakes
40000km/24months
? Change air filter
? Inspect front and rear brakes/replace brake pads
? Inspect valve clearance
? Replace spark plugs
? Inspect and adjust drive belts
60000km/36months
? Change air filter
? Replace engine coolant
80000km/48months
? Change air filter
? Replace tires (Check tires inflation and condition at least once a month)
? Replace transmission fluid
? Replace brake fluid
? Computer diagnostic scan
Throttle body service
100000km/60months
? Change air filter
120000km/72months
? Change air filter
140000km/84months
? Change air filter
? Replace timing belt and inspect water pump at 160000km
? Visually inspect the following every 20000km
? Tie rod ends, steering gear box, suspension components, drive shaft boots, brake hoses and lines, all fluid levels and condition of fluids, cooling system hoses and connections, exhaust system, fuel lines and connections, lights and controls, vehicle under body.
