another major job was changing the front passenger wheel hub as the threads were slipping, new wheel hub had arrived from germany, the bearings were already pressed, i had also ordered a tube of MB green wheel bearing grease.
they had printed out a copy of WIS for the job looked like shahnawaz doesnt do this often
the green wheel bearing grease
the hub
they used this tool to easily take of the dust cap
old hub out
new hub on
now shahnawaz had incorrectly adjust the hub manually but later after a drive i had them re do it with a dial gauge and they did and the job was completed properly without any harm, the new wheel bolts for this i had bought but because i had tried them in the old hub they had also been damaged so to save the new hub got 5 more wheel bolts man these things are crazy expensive new.
they measured the thickness of the discs using a vernier calliper and found them to be below spec also there was a considerable lip on the disc so now next job was to change all 4 discs and pads and brake wear sensor plus the MB brake paste.
