Yes its easy you just require one good quality screw driver and 10mm T handle type tool
first below remove the 10mm size bolts using t handle they are a bit difficult to access but
fix the tool and use a bit of force they will open than you can rotate them out with hand
while tight them do not tight them too much first you can screw them in with hand
than just use one final turn with tool with some force so they are tight do not tight any of bolt
too much as it will loose them
after removing these below 10mm bolts remove two top screws give opposite support hold with
one hand to visor and remove bolts use screw driver which is fixing screws when bottom bolts
are removed visor is on top bolts only so while removing as i said give support of one hand to visor
this will ease removing them and also keep safe visor from falling down
after 4 bolts are moved headlight is opened remove the headlight switch just pull it out
try not to use your force above on holder as it will move the support which is holding bulb
and its holder in fix place so if support is moved bulb will change its position one time this thing
happened after fixing everything at night i noticed bulb throw is not right so again opened visor
and reset the bulb position same mistake mechanic had also done as my bikes visor is opened
2-3 times as i was trying to find out solution for visor noise
