That was another Chinese chopper yingang pak hero 125[Img]https://www.pakwheels.com/forums/attachments/bikes-3-wheelers/393381d1334119665-yingang-pakhero-125-motor-byc-1.jpg[/img]
Also can you share some of the inscriptios on the bike (wheels ?frame ? engine (near chain chian sprocket ). etc they should give an idea of who is the manafacturer of this in china to assess its quality ?
Frame is ditto copy of Suzuki gn 125/250/250 (not confirmed through read it somewhere over internet) engine is replica of CG 125 with 5 gear transmission front and rear alloy/tyres are of same size as of cg
It has PZ26 carb... it is air cooled.. wo Pak hero bike thi jis pe aapne radiator dekha hoga.
Wrong about tyre/alloy size. Front is same as CG which is 18 inch - rear is 16 inch (cg has 17 inch rear rim)
I will take a closer look while cleaning sometime and will let you know.
Hahaha... haan those flaps are real ugly
-------Gear indicator--------
The make of rim is comsung -
-----Front rim is 1.6x18------
------There are some detailing-------
What are the making in engine. They are normally on left side of engine case Judy beneath the sprocket/gear lever
MashAllah bike k sath profile bhi change ... ;D
yesID change hi nahi hota
16" rear wheel is a big plus in any bike, it feels more in control !
How's the engine?Is it vibrating type like CG, or smoother type like GS?
Not to mention, smaller rear wheel (along with the caster angle of front forks) makes the bike more agile to cut corners or traffic.
It is OHV so it means it will vibrate at some point but abhi tu 40-50 ki speed pe chal rahi hai aajkal - but 40-50 tak bohat smooth chalti hai.
Its basically the same engine as a CG125 so yeah, its going to vibrate. And it does. People who have ridden a CG125, will know this in an instant; others may take some time.
I want to paint the mud guards from inside, see its raining now-a-days and I want to protect them from rusting.Suggestions please? Which paint to use? What type and any brand or company name anyone has please?
Most mechanics suggests 7cf spray paint.
No idea if it works or there is some other good type of paint
Ok, thanks. I must go out and see what we can get from market..
very bad paint bro... it rips of in first wash.... Liquid Tarkool is availble in Qurter box for arond 150 and covers both mud gaurds from inside... and its the best solution
