Sides of the cut sheet being smoothed out ..
The edge being carved out
Being checked for size adjustments ...
the left side of the trunk ...
It was discovered that the base was not exactly straight in the car ... so the edges of the upright sheet were slightly shaved to adjust with the original contour of the trunk base.
Upright sheet being checked for size again ..
Now measuring out piece for horizontal piece
The horizontal sheet being checked for size ...
It was amazing to see that while it was not possible to take measurements using a tape ... but he kept on shuttling between the car and the shop to see for even slight modifications required
Madhouse was still in his office, so I was there alone to make timely decisions required
an arc being cut out to make room for the contours
Perfect arc cut..
