Thank you so much Saad Bhai :):)
SS going in for the first time
It was a bit tricky to push amp into place after the addition of upholstery layer
In the above photo, you can see that the wooden spacer is also covered with foam ... so that there is no noise.
Nasir prepared the first pillow
almost in ...
second SS in place too
I had taken glue gun along .... I applied another layer of glue over the holes drilled for support structure
I covered the woofer contacts entirely with hot glue to ensure no leakage and no tarnishing
sorry ... out of focus
