Saturday was a very hot day .. you can see his face
As we removed the plastic protective sheet, we discovered that Toyota had installed sound deadening ... can you see this, or would you like to use a microscope ...!!!
Fittings coming off ...
Madhouse would kill me for taking photo .. but I remembered farmaesh from Bro 2C .... So I did it
check the facial expressions ...
Removing the wiring jacks ..
Please DO COMMENT on facial expressions of Madhouse ..
The wires were coming in the way, so we taped them to the window
With so much wiring in the way, it is difficult job to install something like Dynamat .. it would be best if there is just the metal sheet to work with
Just imagine sitting for hours on the hot floor
Usually one surface of door is dynammated ... but we decided to do it on outer as well as inner sheet metal .. It is easy to reach such areas, but reaching out to depths of the door is difficult
The door was thoroughly cleaned from inside .. Dynamat recommends using a solvent like methyl alcohol for cleaning the surface, but Laadli is a very clean bacha .. so just using the flannel cleaning cloth was enough
