Measuring the inside of the door ... I always keep this measuring tape in my car ... whenever my tailor comes to my office, he comes without his tape ... it is good to have it around in the car
okay .. but then you will have to get a shave
It is okay to make a mistake when doing stuff on paper .. dynamat is expensive, so not advisable to make mistake when you cut the sheet
Due to the metal support pipe installed in the door, the outer deadening had to be done in two steps .. making the top portion pattern
The magic roller coming out of the packing .. yes, it is from dynamat too ... and that means ... VERY EXPENSIVE ...!
Neatly drawn pattern ... now being cut
Let me show you the Roller
Cardboard pattern being inserted to check for size
Roller waiting to be put into action
The top pattern in place
The Dynamat sheets ... exposed first time ..
each sheet is 1.7 mm thick, and has its back covered with stretchable aluminum foil
The pattern needed further adjustments
Pattern placed on top of the Dynamat sheet
10 Blade pl .... (From Gray's Anatomy) .. !!!
Dynamat can be cut easily using the blade or a scissor ..
