Bolt to bolt fit ho jata hai aur accelerator lamba ho jata hai
accelrator lamba ho jata ha ? explain this bro
Yar misal key tor per jub aap 70 ka throtle twist kartey ho to ager woh 1 rotation leta hai to 125 ka carb laganey key bad 1.5 lai ga yani key throtle pehley sey zyada neechey tak ghomey ga
Oky. Ma cd100ka piston use kr rha hun. Cg ke carb k sath i m expectng gud results . Sprocket ratio ki samaj nae arhi mje abhi
Sporcket 15-38 ka combination banao mere dost ney stock chonda per 125 ka carb, 15-38 sporcket ,free flow pod type air filter, aur free flow exhaust kara tha koyi bhi 70, and 100 cc pakar nhe pati thi.
Sprocket k size change Karne se clutch plate bohat jaldi farik ho jati hain
Yar men ney apni chonda men front sporcket 15 teeth dala tha mere dosto ney apni bikes men change kye howey han sporcket mager kisi ki clutch plates fry nhe howi abhi tak
mohsinwahhab Clutch plates tab farq hote hain jab ap bare(big) gerari(spokit) pr wheel(wheeling) marte hoaur 15/38 ki spokit game k waqt lagane chyea warna bike ka engin jald farig ho jate hyMare koi baat samj na aye to bro ap apna qeshtion pouch sakty ho
Nhe yar aap ney itna acha samjhaya hai key "qeshtion" ka to sawal hi nhe banta
[Fcc clutch plates and atlas honda oem pressure plates. Old ones were heated up neded replacement
Sent from my Nokia_XL using PW Forums mobile app
did you install the clutches dry?
nop dipped in oil for half hour
mechanic laughed at it saying its no need . on forums i heard it should be dipped more what you say
Why is dipping needed? I only got it changed twice in my two different bikes one was Pak hero 125 and another honda 125 83. Dont remember anyone dipping them in oil.Also i have a chonda united with 78 head. I am waiting till 10000 kms after that i plan on getting its head opened and get a bigger piston, valve etc. What do you suggest? Also do i need to change the carb as well to Honda 125?
yes - always install a wet clutch set in fully wet condition, I usually dip them one day prior.
automatic gearboxes of cars also have these clutch systems, if you dont dip them - you burn them out - customers get very angry then.
your mechanic was in idiot.
That i have no doubt about it. Mechanics in Pakistan are the hittora type. They do what they learned by watching ustaads and not actual knowledge. I got the engine build thrice of my old 125 but no one could get the job done properly. Finally sold it.
lol - a honda CG125E is so simple to redo that it can be done perfectly while half asleep.
I m using pridor piston in my 70 . Its engine was rebuilt completely and it rattled again in a month . Kharadya say its mechanic fault and vice versa. Biggest issue is that it heats up . As the oil pump is still of 70 it can't keep up with heat
bahi engin oil main clutch plyte keyoin dip krte hain
