so sultan ka khoo will have these kabli parts, never heard of mithu khan,thats also some where in rwp?
i only turned ac on that night to check if it cools down n that night it was actually bringing it down
i guess normal uphill roads might as well show that but if i drive slowly even to pir sohawa it may not effect,sometimes i gear up on uphill roads to keep rpm low where as i remember lower gear should be used to climb up?
i am driving normally,even sometimes slightly pushing till 3k, MASHALLAH no issues, now have adapted as well to this driving style of slowly accelerating n slow push,saves fuel as well though even b4 i used to stay below 3k even while having little fun as above that petrol just starts vanishing
how to check cap will have 1.1 bar pressure? i posted the pic just to know as this one shows 0.9kg/cm but u said its 0.8 bar, so i should ask for 1.1 bar cap for vti 05?
i wouldnt know if it'll be oem kabli or another local but they'll try to push it through wid high price saying it is oem
the one already on it wasnt in such condition n might as well b kabli or something that needed to be changed,last one was working fine but i noticed that plastic bottle was pushing water out, even on closed bottle water was coming out, showed to road side mechanic n he started looking at needle thinking its over heating which it wasnt, i came to this mechanic later,he said everything is fine n told to change radiator cap as its rubber was all worn out, both caps were similar old n new, i think maybe plastic bottle was pushing water out due to over filling as sometimes it gets filled till top now i pour water slowly n till its neck where i can see water in the bottle, filled till that level yesterday, checked today again, a 2.15 litre got 1/4th quarter empty filling it or almost 30-35%
mechanics say that it shouldnt reduce water, though even neck level is over filling but i cant check below that so maybe that water gets over thrown every day n thats why it fills up,even if i check after days almost same level of water needs to be filled
btw it had been n is working fine wid this cap but could be, i did noticed once when it was over heating,water in plastic bottle was till top,why was that? radiator pushes water to that side and/or wasnt pulling? i even thought of trying direct fan but didnt as engine needs to be warm cant stay cool all the time,has to maintain certain temperature
for obd scanner i'll need some shop guy n so far its behaving normally
