@basic sir kindly tell me about filter cleaing.with which thing it will be better to wash it.i mean with detergent,dish wash soap or liquid or just with petrol??? plz eloborate sir
Kerosene
Sent from my LG-F160K using PW Forums mobile app
No dear never use kerosene oil to wash air filter it will weak & crack your air filter foam slowly slowly
No pictures taken.
Thanks a lot Faheem bhai,
I don't know about the mirrors back ground.
BOL for your projects.
No oil test performed after drain.
Apparently it looks dirty in color, which is a good sign.
Performance and noise was good till drain.
Filter element washing gently with mild detergent and water.
(Quality detergents like Brite, Surf.....)
Now time to replace head light.
First tried to draw the simplest sketch for wiring.
Expert advises are needed.
Few things/parts collected.
Head light bought earlier, see post #65.
Cutting out the relay base/connector.
Sleeve insertion for +ive wire.
+ive wire with a fuse loop of 10A.
Good job Nadeem Bhai.
Thimble attachment, joints soldering and heat shrink sleeving.
Only reflector, seal and glass lens of the new head light used.
Body and ring kept original.
Finally mounting of the unit.
Final result is very good.
Now one can ride comfortably in the night.
Good work keep it up & carry on
Thanks
Nadeem Bhai i have a question. A friend bought a zero meter GS150 few days ago. When he start bike there is some missing in it which vanishes after driving few km's.
Carb Setting required.
