main dubara admit karna hn k mujhe shock absorber ki bottle jo disk brake k liye design hui ho uski importance se inkar ni hai
remember disk wai bottle pe bhi caliper braket se hi fit hota hai direct tight ni hota
try karne mein harj ni hai mutmain na ho to hta dena atleat stock shock to apni jaga hoga na
start mein main bhi darr raha tha lekin ab itminan hai
masla ye hai k bottle ka milna aur phr stock se match karna bht mushkil hota hai
2nd is se phle main 2 3 bar alloy install kar chka hn with complete shock absorbers they were fine lekin GS wala maza ni aaya
phr humne konsa gs pe 120+ jana hai even 105 pe maine apni bike se front tire ki awazen nikal kar check kiya hai its fine
bat ye hai k braking stock se bht bhtr hogai aur brake pad ka kharcha aik lambey time k liye off hogaya
see the inspiration isi bahane cg walon ka bhi bhala hojayega
cg125 mein rear disk brake kese ad hua hai
designed plate mein
qareeb k 2 hole caliper k hen
center ka bara hole excell ka hai
aur phr neeche ka aik hole us rod pe fit hoga jispar stock brake plate rukti hai
Motorcycle accessories modified disc rear brake kit high gear hydraulic disc brakes ( without ABS) - ????????? ?????? -EASY-TAOBAO CO., LIMITED
one more link with the designed plate
Motorcycle accessories modified after the brake disc brake disc high gear kit (GY6 Scooter ) - ????????? ?????? -EASY-TAOBAO CO., LIMITED
kawasaki GTO100 mein front bottle disk wali hai with drum brake
kisi ko yad hai ? k drum brake ki plate, disk wali bottle pe kese fit hoti hai
