Confirmed & Purchased.
[TABLE="width: 100%"]
[TR]
[TD="class: title2"]
WARN ZEON 8
Advanced, capable, and strong[/TD]
[/TR]
[TR]
[TD]Don't let the good looks fool you. We've packed the ZEON 8 winch with all the performance features off-roaders said they needed most. From a heat-dissipating brake down to an incredibly smooth planetary gear train, this winch is ready to hit the trail. The 8,000 lb. pulling capacity, combined with a fast line speed make this winch the perfect choice for Jeep and SUV trail rigs.
- 8,000 lb. (3630 kg) single-line pulling capacity
- 100' of durable 5/16" galvanized steel wire rope
- Convertible control pack can be attached to the winch or remotely mounted, allowing for various winch mounting options and looks (Relocation kit required and sold separately*).
- Satin-black powder-coated finish with stainless steel fasteners and clutch lever looks great and inhibits corrosion. Improved winch sealing to keep the elements out.
- Large diameter winch drum reduces rope wear, is light weight, and has an integrated rope anchor for easy rope installation.
[TR]
[TD][TABLE="width: 100%"]
[TR]
[TD="class: title3, bgcolor: #939DA9"]ZEON 8 SPECS/PART NUMBER[/TD]
[/TR]
[TR="class: altrow, bgcolor: #EBECEE"]
[TD][/TD]
[/TR]
[TR]
[TD]Rated line pull: 8000 lbs. (3630 kg) single-line[/TD]
[/TR]
[TD]Motor: 12V DC, series wound[/TD]
[/TR]
[TR]
[TD]Electrical controls: Contactor[/TD]
[/TR]
[TD]Remote Control: Remote switch, 12' (3.7m) lead[/TD]
[/TR]
[TR]
[TD]Geartrain: 3-stage planetary[/TD]
[/TR]
[TD]Gear ratio: 162:1[/TD]
[/TR]
[TR]
[TD]Clutch (freespooling): Rotating ring gear[/TD]
[/TR]
[TD]Brake: Automatic mechanical cone[/TD]
[/TR]
[TR]
[TD]Drum diameter/Length: 3.15"/9.0" (80mm/229mm)[/TD]
[/TR]
[TD]Weight (kit shipping): 94 lbs. (42 kg)[/TD]
[/TR]
[TR]
[TD]Rope: 5/16" x 100' (8mm x 30.5m) steel[/TD]
[/TR]
[TD]Fairlead: Roller[/TD]
[/TR]
[TR]
[TD]Recommended Battery: 650 CCA minimum for winching[/TD]
[/TR]
[TD]Battery leads: 25mm gauge, 72" (1.83m)[/TD]
[/TR]
[TR]
[TD]Finish: Satin-black powder coat[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD="class: title3, bgcolor: #939DA9, colspan: 4"]12V DC PERFORMANCE SPECS[/TD]
[/TR]
[TR]
[TD="width: 25%"]Line Pull
Lbs.(Kgs.)[/TD]
[TD="width: 25%"]Line Speed
FT./min(M/min.)[/TD]
[TD="width: 25%"]Motor
Current[/TD]
[TD="width: 25%"]Pull by layer
layer/Lbs(Kgs.)[/TD]
[/TR]
[TD]0[/TD]
[TD]42 (12.8)[/TD]
[TD]63 amps[/TD]
[TD]1/8000 (3629)[/TD]
[/TR]
[TR]
[TD]2000 (910)[/TD]
[TD]17.2 (5.2)[/TD]
[TD]167 amps[/TD]
[TD]2/6777 (3074)[/TD]
[/TR]
[TD]4000 (1810)[/TD]
[TD]11.7 (3.6)[/TD]
[TD]255 amps[/TD]
[TD]3/5878 (2666)[/TD]
[/TR]
[TR]
[TD]6000 (2720)[/TD]
[TD]8.5 (2.6)[/TD]
[TD]335 amps[/TD]
[TD]4/5189 (2353)[/TD]
[/TR]
[TD]8000 (3630)[/TD]
[TD]6.2 (1.9)[/TD]
[TD]413 amps[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
This is enough for my setup & requirement.
