dont fit automatic gear in baleno manual gear ka apna maza hota hay and according to my information i havent seen anyone wid automatic gear in baleno.i think its impossible.purchase some factory fitted automatic gear car like civic and city but according to my experience automatic cars are very expensive to maintain and not smooth as manual cars.dhakay say start bhi nahin hoti.
hamad bro baleno is an exellent car without any doubt purchase it.but keep in mind 2005 is the bast in its class .purchase fully electronic car means with coils system not manually converted system uus ki market bohat kam hoti hay like 5 lac but geniun 2005 6 lac tak hoti hay.mechanic ko saath lay ker jana.coils ko achi tarah check ker laina.best of luck
yaar agar tu aap ki car petrol pey bhi same harkat kerti hay tu then i think some timming in out timming belt tu change nahin kerai.also check ur gear box and clutch plate by some gud mechanic
(triple A) saddar rawalpindi name aslam
aap agli dafa denso k plugs dal k dekho phir batana.also use small tyres of 14 or 15 inch dont use big and radial tyres for grace these are not good for ur suspension and also eat more fuel.
u can get 2005 model islamabad no in gud condition in 6 lac.6 lac is enough for a gud car.
aap apni battery check ker lain.check its expiry date.check its water and ph level.mray khayal say aap ko rpm drop ki problem hay.agat tu aap ki rpm needle up down hoti hay still per tu clean ur throttle body.tune the car,cng kit ki servive is must.release clutch on 2 rpm for better pick.
its not dangerous but gear oil sath sath check kertay rehna aur time nikal ker kam kra lain its good verna koi gear slip bhi ho sakta hay.its better for ur gear box life.but agar na honay k braber leak ho raha hay tu rehnay dain kiun k yeh oil bohat thick hota hay aur in winter aur thick ho jaey ga saath saath check kertay rahain oil level.kam ho tu aur dal laina.
agar petrol per missing ker rahi hay tu advancer ya ammulater dono main fault ho sakti hay.check it by some good cng mechanic.
guys im back for ur help. i was out side the city and waz little buzy thats y i cant reply to ur posts.
