<article>[INDENT]PRIUS 2010 Specs:
Hybrid System Net Horsepower 134 horsepower
ENGINE 2ZR-FXE (Atkinson cycle)
Type, Materials 4-cylinder aluminum block and head, double overhead cam (DOHC) 16-valve VVT-i
Valvetrain 4-valve/cylinder with VVT-i
Displacement 1,798 cc
Bore x Stroke 3.17 x 3.48 in.
Expansion Ratio 13.0:1
Horsepower (SAE Net) 98 horsepower @ 5,200 rpm
Torque 105 lb-ft @ 4,000 rpm
Recommended Fuel 87-octane unleaded
Emission Certification SULEV (with AT-PZEV) Tier 2 Bin 3
EPA Estimated Fuel Economy* (city/highway/combined MPG) 51/48/50
MOTOR GGENERATOR TWO
Function Drives front wheels, regeneration during braking
Type Permanent Magnet Synchronous Motor
Max Voltage DC650V
Electric Motor Power Output 80 hp/60 kW
Torque 153 lb.-ft.
HYBRID BATTERY PACK
Type Nickel-Metal Hydride
Nominal Voltage DC201.6V (168 x 1.2V cells )
Capacity 6.5 ampere hour
Battery Peak Horsepower Rating 36 hp/27kw
System Voltage 650 volts maximum
* 2010 EPA MPG estimate. Actual mileage will vary.
DRIVETRAIN
Transmission Type Electronically controlled continuously variable transmission (ECVT)
CHASSIS AND BODY
Suspension - Front - Rear Independent MacPherson strut suspension with stabilizer bar Torsion beam with stabilizer bar
Steering - Type - Turning Circle Diameter (curb to curb) Electric power-assisted rack-and-pinion 17.1 ft. (15-inch tires) 18.0 ft (17-inch tires)
Brakes - Front - Front Diameter - Rear - Rear Diameter - Parking Ventilated front disc (hydraulic with power assist) with standard Anti-Lock Brake (ABS) system and integrated regenerative brake system 10.0 in. rotor Solid disc (hydraulic with power assist) with standard Anti-lock Brake System (ABS) 10.2 in. rotor Pedal brake
Anti-lock Brake System (ABS) Standard
Wheel Size 6J x 15 in. 7J x 17 in. (available)
Wheel Type and Material 5-spoke aluminum alloy
Tire Size P195/65 R15 P215/45 R17 (available)
Tire Type All-season
Spare Tire/Wheel Temporary
EXTERIOR DIMENSIONS
Overall Length 175.6 in.
Overall Width 68.7 in.
Overall Height 58.7 in. (with 15-inch and 17-inch tires)
Wheelbase 106.3 in.
Tread Width (Front/Rear) 60.0/59.8 in. (15-inch tires) 59.6/59.4 in. (17-inch tires)
Front Overhang 35.6 in.
Rear Overhang 33.7 in
Ground Clearance 5.5 in.
Coefficient of Drag 0.25
INTERIOR DIMENSIONS
Seating Capacity 5
Headroom (Front/Rear) 38.3/37.6 in.
Legroom (Front/Rear) 42.5/36.0 in.
Shoulder Room (Front/Rear) 56.1/53.1 in.
Hip Room (Front/Rear) 52.7/51.2 in.
EPA Passenger Volume 93.7 cu. ft.
EPA Cargo Volume 21.6 cu. ft.
WEIGHTS AND CAPACITIES
Curb Weight 3,042 lbs.
Fuel Capacity 11.9 gal.
STANDARD EXTERIOR FEATURES
? P185/65 R15 all-season tires on 15-inch aluminum alloy wheels
? Color-keyed foldable power heated side mirrors
? Driver door Smart Key entry system with push button start and remote illuminated entry
? Aerodynamic multi-reflector projector-beam headlamps with auto-off
? Rear window electric defogger with timer and intermittent wiper
? Aerodynamic rear deck spoiler
? Roof-mounted XM Satellite? radio antenna and wiring harness
? High Solar Energy Absorbing (HSEA) glass
? Washer-linked variable intermittent windshield wipers
STANDARD INTERIOR FEATURES
? Tilt/telescopic adjustable steering wheel with audio and HVAC controls with Touch Tracer Display
? Multi-information Display with energy monitor, fuel consumption history, hybrid system indicator and odometer with twin tripmeters.
? Central instrument display with digital speedometer, instant fuel consumption, fuel gauge, shift-lever indicator.
? Air conditioning with electric A/C compressor
? Eco, EV and Power mode
? Auto up/down on all windows
? Push button start
? Cruise control
? Driverβs seat with vertical adjustment
? Dual sunvisors with driver and front passenger vanity mirrors
? 60/40 split rear seat
? Power door locks
? Seatback pockets
? 12v power outlets (2)
? Tonneau cover
STANDARD AUDIO SYSTEM
? AM/FM/single-CD with MP3/WMA playback capability, auxiliary audio mini-jack, six speakers and satellite capability
STANDARD SAFETY AND SECURITY
? Driver and front passenger advanced airbags, driver and front passenger seat-mounted side airbags, driver knee airbag and front and rear seat side curtain airbags
? Side-impact door beams
? Front and rear energy-absorbing crumple zones
? Three-point front seatbelts with pretensioners and force limiters, ALR/ELR retractors on all passenger seatbelts, three-point seatbelts in all five seating positions
? Star Safety System: Regenerative Anti-Lock Brakes (ABS) with Brake Assist (BA), and Electronic Brake-force Distribution (EBD) Vehicle Stability Control (VSC) and Traction control (TRAC)
? Active headrests
? Child protector rear door locks
? Adjustable front seatbelt shoulder anchors
? Engine immobilizer
FACTORY OPTIONS
? Navigation Package β Voice-activated touch-screen DVD navigation system with JBL AM/FM/four-CD changer with integrated XM satellite radio, MP3/WMA playback capability, hands-free phone capability via Bluetooth? wireless technology, eight speakers, backup camera
? Solar roof Package β includes all contents in the Navigation Package, a powered tilt/slide moonroof with solar powered ventilation system and remote air-conditioning system
? Advance Technology Package β includes all contents in the Navigation Package; Pre-Collision System, Dynamic Radar Cruise Control, Lane Keep Assist (LKA) and Intelligent Park Assist (IPA)
[/INDENT]</article>
