Displacement, 1496 cc
Exterior dimensions (LxWxH), 4195 x 1695 x 1515 mm
Interior dimensions (LxWxH), 1645 x 1405 x 1245 mm
Wheel base, 2550 mm
Treads (front/rear), 1450 mm/1455 mm
Ground clearance, 155 mm
Curb vehicle weight, 1110 kg
Gross vehicle weight,
Seating capacity, 5 persons
Doors 5
Min.turning radius,5.2 m
Fuel tank capacity, 50 L
Engine model 1NZ-FE
Max.power (Net), 105 PS (77 kW) at 6000 rpm
Max.torque(Net), 14.1 kgf?m (138 N?m) at 4200 rpm
Power density 10.57
Engine type Serial 4 cylinder DOHC
Engine information VVT-i
Fuel system EFI (electronic fuel injection)
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 10.5
Bore, 75 mm
Stroke, 84.7 mm
Power steering
Tires size: 165/80R13
Braking system, front : ventilated disk
rear drum (leading/trailing)
