1)Very small turbo means power on low revs and will increase back pressure on high rpms
2)even if go past rev limits you run risk of breaking con rods and piston hiting valves not melting piston on petrol engine by the time heat reach the point where piston melts your spark plug will be gone try running extreme lean and see if piston melts or spark plug tip
3)low compression engine can run on high boost
