Now next step is of Sub installation. Sub is already on way and i need the dimensions of the sealed box. As per manual (Link below) 1cubic feet internal volume is recommended for sealted enclosure. @madhouse12 , @roms , @yawar538 Pl help me out for dimensions of box tuned at 27Hz.
Other tech spec on the link:http://www.manualslib.com/manual/284732/Jbl-P1224.html
There are two ways you can go around it.
Remember, these are for the SQ environment and your mids should be strong enough to match with the sub output.
@roms thanx for your reply. forgive my noobness, i did not get what you have written. Pl explain what dimension to use in scenario#2 in term of LxWxD of box, port dimensions and mounting hole diameter. Thankyou
