Trouble Area: - Accelerator Pedal Position Sensor.
- ECM
Solution:
This DTC relates to the Accelerator Pedal Position (APP) Sensor. Replace the whole accelerator pedal assembly (located to the right side of brake pedal) with a good known one even purchased from the junk.
Delete the code manually or with any scan tool. Relearn the idle air control valve and enjoy.[/QUOTE]
one of my friends car has the same issue can you recommend some one at Rawalpindi who is good as EFI electrician and whats the cost of Accelerator pedal new? or old ?
