There may be following marks found beside the mileage description:
"$" indicates that the speedometer has been replaced
"*" indicates that the speedometer does not show the true mileage
"#" indicates that the mileage is unknown
Grading
Overall Grades:
Grade S/6: Brand new vehicle.
Grade 5: Like brand new vehicle.( Usually under 50kms or less than 3 years old.)
Grade 4.5: Excellent condition vehicle. (Has little tiny stone chips, slight scratches or dents on the body).
Grade 4: Good condition vehicle. (Has a few scratches, dents on the body as normal used.)
Grade 3.5: Average condition vehicle. (Has a few scratches, cracks or dents on the body larger than a palm?s size.)
Grade 3: Poor condition vehicle. (Worse than grade 3.5, not recommend to buy.)
Grade 2: Bad condition vehicle. (Worse than grade 3, not recommend to buy.)
Grade 1: Heavy modified or racing vehicle.
R/RA/A/A1: Accident history vehicle or modified and accident history vehicle.
*** : Damaged vehicle not been repaired.
Interior Grades:
A: Brand new or as brand new condition.
B: Very clean and good condition.
C: Average condition. (Has at least one defect. Like dirty mark on seats, scratch on dash board/trim/door panel or cigarette burn.)
D: Poor condition. (Few burns, breaks, cuts may cannot be removed.)
Inspection Codes:
A1: Scratch (Size around 30mm.)
A2: Scratch (Size around 150mm.)
A3: Scratch (Size bigger than A2.)
C1: Corrosion
C2: Heavy corrosion/hole.
E1: Slightly visible dent/stone chips.
E2: Few slightly visible dent/stone chips.
E3: Many slightly visible dent/stone chips.
G: Stone chip (windscreen).
H: Faded painting.
P: Repainting required.
S1: Rust
S2: Heavy rust.
U1: Dent (Size around 30mm.)
U2: Dent (Size around 150mm.)
U3: Dent (Size larger than U2.)
W1: Quality work on panel repainting.
W2: Slightly visible repair works/repainting.
W3: Obvious repair/wavy panel need to repaint.
X: Replacement required.
XX or XXX: Replaced.
Y1: Small hole or crack (thumb size).
Y2: Hole or crack (palm size).
Y3: Big hole or crack (larger than Y2).
