Any expert in abs....?
Some days ago i went to toyota 3s for abs light they check and diagnose that front left side abs sensor was mulfunctiong we could not find it in market so cannot change at that time now i change it on my own.. but the problems exists.. when i jumper the pin 4 and 13 on OBD and ignition switch is on then abs light blinks for 1 time and then it continues blinking i count it 200 but it was continuing blinking.. then i turned off thr ignition key... repaet the procedure then the same behaviour of abs light... any abs expert explain the problem.... as i cannot go back to toyota 3s as it is far away i am living in remote areas of KP.... any help will be highly apreciated...
Sent from my SM-A500H using Tapatalk
