maybe the noise is because of multiple bearings
you corrected one
now identify the other
in most cases the idler pulley bearing is shot.. however check using a stethoscope.
if the ac compressor is not the original, check and double check the alignment of the compressor.
if the serpentine belt needs replacement.. do so because it can be noisy as well.
