My vitz strted slip its self (ignition). De electrixan says its pulley is getting slip. Common in xli corolla and vitz. My question is does only pulley is issue or there is more anything invlved too. Lyk flywheel etc...
what do you mean by slip ? it is a VVTI engine - anywork done over the engine or in the engine bay lately ? @syncview @argtr65 @xulfiqar @rustam54 @naweed @ser_gtr
starter slip is usually the starter motor brushes or its coil or the solenoid ... then the fly wheel teeth but pulley is not associated to starting ...
Try to get it repaired asap otherwise it will damage your fry wheels as well. I got mine replaced few months back and it costed me 600 Rs for whole new ignition system.
Nops never any kind of work in engine. Purely driven 84,000kms on petrl. Im de frst owner of dis car. From japan till now.
So called girari slip hrhi hai. I askd my frnds who kept gli corolla etc. Dey said yes its common. Wid 1.5 yrs issue comes...
Yani drive assembly which is in 1st pic...
my apologise, i mis-read your french lines. - you mean to say the starter motor malfunctioning and car is not starting in 1st few cranks.
as shared by @naweed @sd please visit a competent electrician who can remove & examine the starter motor pinion gear & fix it.
Check starter solenoid,Bendix drive,pinion & ring gear for worn out.
Replace The Starter ASAP If Teeths Are Gone...Else Check Your Solenoid
fry wheels... hmmmm - karhai mein tyre?
No, Karahi Mein
