@testdriver
AOA.... Everything got fine in my Racer except IAC Valve. I am unable to find new IAC bought Kabli from Mithoo Khan . Replaced two times but idling problem still there (some times RPM shoots to 2000 on idle normally up and down and engine stops). IAC valve should move out 1 cm ( 10 mm) but both IAC valves moves 2/3 mm outward and inward on ignition off.
From Where can i find new IACV?
My Car Engine Overhauled recently: new Cam , new head , cylinder bore at 100
New TPS,
New ECM with KAbli Mem-CAL (code 12 displays while shorting A & B of ALDL),
new MAP Sensor ,
new CTS,
KAbli VSS installed
Kabli working ignition module.
New injector.
Kabli ICAV which moves a slight (2 to 3 mm) but if engine starts it moves litlte longer
Problem only on Petrol
Wiring of every Sensor to ECM is OK
Voltages at every Sensor is as per requirements according to Manual.
