Getting pulse from distributor is correct, it should be done like that. This sense to turn on the ECU system when the pulse is on.The ECU has another sensor for speed also. You have to connect that with the speedometer board (from where the speed needle gets input). Though it does not work perfectly, but still it serves the purpose quite effectively. In digital cars, the ECU even cuts of EPS over speeds higher than 100.But in analog cars, analog pulses are converted to digital ones (w.r.t the time division) and serves the purpose quite a bit.
i want to install EPS in my cultus 2002 manual, not efi , is it available in bilal gunj , can it install , and will it be working properly , and its softness will be change on high and low speed ,
Eps for cultus is available here in peshawar shuba bazar(Kabali bazar) for 5K....
and one of my friend got it installed in 2007 alto which rocked the car, feels awesome....
Brother, you have wrong information. Alto does have VSS, and it perfectly works. I just got EPS installed in my Uncle's car, working perfectly on low speeds and low rpm, and getting hard on high revs and above 40 kmph.
I appreciate your detailed reply bro. ThanksHow much it cost and how to find a nice one from shershahwhat is the inspection procedure
LOL I use to drive always with one hand, people sitting next to me often thinks I have a power steering in my cultus VXR
proper air pressure in tyres and who needs power steering as long as u don't do a lot of three point turns.
Bro mere pas Nissan sunny 1990 model hai me iske manual windows KO power Karna chahta hun . is it possible ? If yes then how much will it cost ?
Hay guys..please tell me about the cultus hydraulic power steering repair...can we repair the steering? If not then how much the cost of replacing with new/kabli one..and where I can find best mechanic in rawalpindi?Appreciate your prompt response in this regard..
how will it cost me to convert euro-2 cultus to eps
how much it will cost to covert cultus euro-2 to eps
how much it will cost to covert into power windows
also tell me that can i replace suzuki genuine 2006 cultus vxl power windows in euro-2 cultus.from where i could get orignal 2006 models power windows
can you tell what is shershah and where it is located
from where to get??
Sorry brother out of topic question can u tell me which car is the best in 660 category?
That was comprehensively explained. Thanks
