Dear Members,
I've got a Vitz 2005 1.0Ltr KRFE. You know the famous TAK TAK TAK noise coming from the front tire when making a U turn. Well, just I heard that coming from my Vitz left front tire. So, I took it to the mechanic and he said after looking at it that I would need to change the whole left "goddaa" as they say it out here. I was in shock as how can a "goddaa" be damaged and all I hear is the TAK TAK TAK noise it had to be worse than that if the goddaa was damaged right?
Anyways took it for second opinion to another mechanic and he said to me that you simply need to change the kit of the left side's goddaa! This is where I am confused and would like to ask you what is the issue when the noise of TAK TAK is coming from the front left side tire only and only on U turns?
Should I change the whole "GODDAA" as recommended by the first mechanic or just the kit? Apparently at this point I'm not even sure what a "kit" of the goddaa is honestly. Clarification needed. Thanks!
P.S Forget to mention could you also mention out in the market here what part to ask for as I remember the mechanic telling me there are Japanese, Chinese & Kabuli original ones.
