salam i have khyber 1996 original/ genion ac. i have serviced its ac before one month ago. the car is heating but the ac work well. please suggest me.? my cell is numbre 03234417668
i also have khyber and faced the similar problem!just go and change its radiator with double channel plastic body radiator ( DENSO) !i m sure the problem will be solved!gasket can also be an issue but its rear!
thanks zeejigs... how much costly this radiator which you suggested and where i found and fitt in lahore?
I got the same problem... how much is that denso radiator you suggested.
