Results 1 to 8 of 8
Thread: Toyota Belta 2006 - Gear Information
    jaaf's Avatar
    Nov 2006
    406
    Default Toyota Belta 2006 - Gear Information
    Toyota Belta 2006 - Gear Information -593956
    hey guys
    whats the function of these
    1. Shift Lock
    2. S
    3. B
    mafzaltareen's Avatar
    Sep 2005
    2,269
    2 Post(s)
    shift lock=you can move the car by shifting the car to "n" without starting the car by using shift lock
    S=the car keeps in second gear
    B=keeps in first gear if you need pawer on ramps with load.
    http://www.facebook.com/V8Rx8
    panicslayer's Avatar
    Nov 2008
    35
    10,044
    10 Post(s)
    Shift lock=When u can't start the car and u have to push it or tow it, by pressing shift lock, u can move the lever to N position
    S=can't tell u exactly, some refers it to sports and some refer it to second. But car shifts at high RPM's in this mode, good for acceleration and boost
    B=Engine braking / low gear
    Suggestions required
    jaaf's Avatar
    Nov 2006
    406
    @all
    Thanks
    moizhusain's Avatar
    Aug 2006
    32
    680
    3 Post(s)
    is the auto transmission in Belta CVT or conventional?
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    1000cc belta is CVT...
    and 1300cc belta is four speed...
    murtaza_murti2's Avatar
    Mar 2009
    86
    178
    1. Shift Lock=When your vehicle is not working or your too lazy to move your car in a parking.It's main reason is to move gear's without having to turning on the vehicle
    2. S=Sports mode.I myself have seen that after 80Km/hr when you shift it in ''S'' from ''D'' you will feel the gear changing at a higher RPM and it improves speed!
    3. B=For going uphill it's used in when going up slopes or hills.It uses one single gear to take the vehicle uphill
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    You got your answers here but why not to ask further at
    " ! B E L T A OWNERS & FAN C L U B ! " ?
