Dear Experts,
I have Belta 2007, millage is 10K almost. Problem is blue smoke with very high or can say with Full RPMs.
Oil reduce very low even after 5000 KMs.
Before, changing Engine assemble i would like to take you suggestion, that are the possible cause of Smoke.
Because i have observed, Oil in my air filter Box and as my machnican its due to breather valve.
if this issue is due to breather value its means that Engine oils is going to max with oil intake and causing blue smoke
Am i Right?
one more thing .... i also want to do some work for my suspension and hisa
Please suggest a recommended workshop or person for the solution of above both issue.
Thanks in advance
