Salam
it will be a pleasure for me
if this thread will be useful for any pakwheeler to do so,
all i did, is detailed in these pictures
the thing i tried to do that
no nut bolt,
no parmanent fixing that hurts the genuine fitting
all i do is on one sided textured plastic sheet and tied with the plastic ties
and this sheet is normally available as well as plastic ties
i brought this sheet from shop near by sabri nihari hotel, urdu bazar karachi
the sheet is mold able without any heating process
plastic ties are available at any electronic market in different sizes
first i cut the paper sheet the after finalizing the size i cut the same one
from the plastic sheet and use the sand paper on the edges
in the mudflap i cut the special arc for header due to its heat
and the holes are for some air ventilation
mudflap is tied on only 3 ties
and meter shades are on single tie separately
