Before going through thread Please notice I am not a seller nor a broker Just went to Kacha Ravi Road and Found a Alteration Shop thought to share it with PW Guys.
We all know when it comes to performance most of the big 'Look Alike' bikes fail badly in acceleration specially and heat up if over loaded or used in hilly areas or if put to test on a very long hours I.E. UNDERPOWERED
I mean you name it : Paiggio is a Big Time Looser in accelration when it comes to compare with CG
GS being 150cc and having more horses has almost matching or slightly better performance but still if used frequently on Top power it deprecates due to very less power difference. Deluxe well ... you know
even AHL is planning to discontinue it and launch CG-DREAM soon.
Solution:
I have been noticing from atleast last two months while commuting that modified paiggos which are seend one or a two every day on Canal or Mall road couple of times the were really fast and I was 100% sure this is not a stock engine pumping this much torque so I happen to investigate few paiggios on red signal and I was correct the had some other engines (and they were not rick shaw engines either)
So I started to hunt from where these engines are comming, so I tracked few contacts of famous paiggio alteration shops and VOILA I found a Dungen of Deluxe / Paiggio Alteration..
Engines from 150cc DOHC/SOHC, 180CC, 200CC, 217cc, 233CC, 249cc were available price was rangine from 16k to 30k for 250cc DOHC 6 gear 4 Valve engine (Astonishing) and were in Twin piston and single piston different categories as well.
1 - 200 and 217cc Engines (4 Valve SOHC Water Cool Radiator Engine 6 gears as told by the vendor Price 20 and 25k):
2 - 250CC (4 valve Big Clutch proper Heavy Bike engine)
3 - Suzuki 250cc Used Engine (but Full healthy condition inside prices were below 30k for all engines)
4 - CD 70 Alteration Hogs Japanese HONDA Engine @asjdm chweck this out 160cc and 180cc engines for 15k
150cc and 200cc air cooled engine
DOHC Water Cooled 4 valve 200cc engine
Twin Cylender CA250 engine (same I am using in my Road Master)
150cc Golden Chrome engine
