Dear all I have charade 86 and it had rear view mirror which vibrates while driving the car and after watching back side from that mirror it seems the mind is vibrating like it. Iska koo hal nai ? I guess it's fake mirror or copy or its mehran mirror any one give me idea is me dosri gadi ka fit hojaega ? And iski vibration kese rukyagi ?
LoL @ mind vibrating
there is a screw at the back sidecheck if it exists. tighten it up from there
Hehe bro I will tight those nuts and update you about it
nothing major.... just that the screw is loose.....does the entire mirror assembly vibrates or is it just the mirror fitted inside the assembly???bas nut dheela hai baki aur koi issue nahin.... mjay nai lagta ye itni bari cheez hai k agar kisi aur gari ka ya jaali mirror lagaya jaye tou wo vibrate karega
Bro mene pakar k dekha tha assembly is fixed like fevicol but mirror vibrates like zin zin zin . uska peechay nut hai I asked father he said k already tight kardia tha then phr vibrate marta hai me again check krduga and I bet yeh mirror mehran ka hai q k size b chota hai n bilkul edge per cover krta hai back diggi. Please suggest k corolla waghera ya kisi or gadi ka.lag jaega ?
is it tigthened with correct spring washers?
you may need to add a rubber shoe to its neck to brace it against the windscreen glass.
Bro its tightened wtih only washers the main frame and its fix not moving . where I need to put rubber ? In main assembly jaha body me fix hai ? Because vibration coming to mirror only
Post a pic.
Sent using Curiosity's onboard communications sytem.
rubber is fitted behind the stalk, if your stalk is solid and the mirror is shaking - the assembly is worn out. replace it.
Bro I am posting pics actually time nai mil rha tha
Another view
Please suggest now
Bhaio koi rear view mirror batado axha jo fix hojae bada b ho
