BPR5E-11 This is the plug that fits the G10 Suzuki.
BKR6EKPA this is the alternate of PMR7A used in Ferraris, both are NGK. This is done so for comparison reasons.
1st Field Thread diameter.
B=14mm
2nd Field Construction.
K=hex size 5/8 with projected tip (ISO)
P=projected insulator type
R=resistor
3rd Field Heat range.
2=hot, up to 10=cold.
4th Field Thread reach.
E=19mm
5th Field Firing end construction.
A=special design (no details given)
P=platinum tip (premium)
K=2 ground electrodes
6th Field (after the dash) Wide gap.
11=.044"
Fli I still say they fit coz they both are 14mm thread diameter, and reach is 19mm the only problem there is of the wires fiting the plugs, but i am not too sure about that.
