Okay so we've had those monotonous Corolla Vs Civic comparisons for yonks, without anything substantial being posted. So i though i'd get your views regarding the following.
The cars i thought would be appropriate are;
The Toyota Caldina GT-4 N Edtion Wagon.
The Mitsubishi Evolution 9 Wagon.
The Mitsubishi is, as apparent, based on the sports sedan, significantly strenghtned to handle all that excess weight and minor revisions to the suspension. Available in GT and GT-A spec. From what i've examined, carries over most of the features from its aggressive twin like ACD, AYC AND the Mivec 4G63T. power is rated at 280hp and it gets the 6 throw as well.
On the other hand the Caldina, is the unsung hero here. Featuring full time 4WD and the ever loved 3S-GTE rated at 260hp. comes in at 1490kg which is 10 Kgs heavier than the Mitsu Sedan and 3 lighter than the Mitsu Wagon. The only potential hinderance i see is that the 3S-GTE is mated to a 4 speed electrinoc slushbox.But dont let that fool you. Specs for both are as follows.
Toyota Caldina GT-4 N Edition (LA-ST246W).
ENGINE:
3S-GTE, Inline 4, DOHC, Turbocharged and Intercooled.
TRANSMISSION:
4Speed ECT with sport sequential shift matic .
PERFORMANCE:
Power 191.0kW@6200rpm
Torque 324.0Nm@4400rpm
0-102kph=5.82secs
SUSPENSION:
Front:
McPherson Strut (Independant Type)
rear:
Double Wishbone
BRAKES:
ABS,Ventilated and Cross Drilled Front.
Ventilated discs rear.
MITSUBISHI EVO 9 WAGON (CT9W):
ENGINE:
4G63T, 2.0, Inline 4, DOHC, Turbocharged and intercooled with MIVEC.
TRANSMISSION:
6SPD Manual.
PERFORMANCE:
Power bhp (kW) at RPM: 280(206) / 6500
Torque lb-ft (Nm) at RPM: 289(392) / 3000
0-102: Not tested but definitly a couple of tenths or even second off the Sedan.
BRAKES:
Brakes F/R: ABS, vented disc/vented disc
[ATTACH=CONFIG]465347[/ATTACH]
[ATTACH=CONFIG]465348[/ATTACH]
[ATTACH=CONFIG]465349[/ATTACH]
[ATTACH=CONFIG]465350[/ATTACH]
[ATTACH=CONFIG]465351[/ATTACH]
[ATTACH=CONFIG]465352[/ATTACH]
I could go on and on but then you know how some folks get their panties in a twist, so i'll welcome your views and opinions especially from folks whove driven one or the other.
Ladies welcome!
