Sony 1200watt car amplifier for sale!
Sony's XM-2002GTW Limited Edition Xplod amps combine form and function in a mix that'll make your system look and sound great. On the outside, the sleek inverted heat sink keeps vital internal components running cooler and lasting longer. Removable terminal covers keep all the wire connections protected and out of sight for a clean-looking installation.
Underneath the hood, the 2-channel XM-2002GTW delivers 200 watts to two channels, or 500 watts in single-channel operation ? plenty of power for many subwoofer systems. Signal-sensing speaker-level inputs activate the amp automatically when you turn on your factory radio, so there's no remote turn-on lead for you to install.
You can adjust the frequency filter on XM-2002GTW to tailor the signal going to your subs, while a bass boost adds extra punch to the lows. Preamp outputs simplify setup when it's time add another amp to your system. This amplifier also Tri-mode capable, which means you can run 2 speakers and 1 subwoofer on this amplifier at the same time (crossover required).
Performance XM-2002GTW
RMS Power Output 200W x 2
Peak Power Output 400W x 2
Power at 2 Ohms 250W x 2
Bridged Power 500W x 1
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Frequency Response at Rated RMS Power 20 - 20 kHz
THD at Rated RMS power 0.1%
Input Voltage 14.4v
Features XM-2002GTW
Amplifier Class AB
Low-Pass Crossover Frequency 50 - 300 Hz
Low-Pass Slope (dB / octave) 12 dB
Bass Boost Yes
Bass Boost Frequency 40 Hz
Fan Cooled No
Fuse Rating 40A x 2
Speaker Level Inputs Yes
Preamp Outputs 1 pair
LED Power Indicator Yes
Dimemsion (W x H x D) 15.2" x 19.9" x 2.2"
This amplifier can easily power 2 12" woofers
Condition of the amplifier is V.good & is currently installed in my coure running 1 sub n pair of 6x9 speakers.
When lights go off,this amplifier rocks in looks!
The amp is working perfectly fine and is in v.good condition!
You can google this product to find out the current price which is 119$ us
My demand is 9000pkr.
Contact me 0343-2913398
For picture check out this link: http://www.caraudiodiscount.com/images/SONY-XM2002GTW.jpg
