Hey guys,
i am selling these newly bought components,never used them,nor took them out of the box, they are brand new...
1.FUSION PP-CM65(powerplant series): *(sold)
PP-CM65
PowerPlant 6.5" Component Speaker System
Detailed Light-Weight Polypropylene Cone
Rigid, light-weight cone for accurate reproduction of mid bass frequencies.
Industrial Cast Basket
Provides maximum structural stability enhancing sound quality
Moulded Terminal Wire Connector
Ensuring fluid connectivity and consistent sound through specifically moulded terminal wire connections
Sound Dispersing Tweeter Housing
The PowerPlant tweeter housing disperses high frequency sound, expanding the sound stage.
Gold Plated Connectors
High end componentary and gold plated wire screw connectors ensure fluid connectivity
Product Specifications
Max Power Rating: 180 Watts
RMS Power Rating: 60 Watts
Compliance (Cms): 676.3
Cone Area (Sd): 13.68
D.C. Coil Resistance (Re): 3.3
Electrical Q (Qes): 0.733
Force Factor (Bl): 4.48
Free Air Resonance (Fs): 55
Frequency Response:52Hz - 21kHz
Impedance (Nominal): 4
Mechanical Excursion (mm): 12
Mechanical Q (Qms): 7.04
Sensitivity (dB) (1W/1M): 91
Total Loudspeaker Q (Qts): 0.66
Magnet Structure (Oz): 12.6
2. FUSION EN-CM65 (encounter series):
Encounter 6.5" Component Speaker System
Polished Chrome Chassis
Solid basket chassis protected and detailed in chrome. Stunning sound, stunning looks
Balanced Motor Structure
Designed for efficiency in sound delivery, featuring a highly charged motor assembly
The Encounter tweeter housing diffracts high frequency sound, expanding the sound stage
Three Way Tweeter Attenuation
Accurately controls the level of tweeter output at -3dB, 0 or +3dB
Tweeter Poly Switch Protection
Incorporating PCB tweeter protection to safeguard your tweeter from unwanted signal clipping
Max Power Rating (Watts): 240
RMS Power Rating (Watts): 70
Compliance (Cms): 578.4
Cone Area (Sd): 11.9
D.C. Coil Resistance (Re): 3.6
Electrical Q (Qes): 0.77
Force Factor (Bl): 4.5
Free Air Resonance (Fs): 56
Frequency Response: 53Hz - 22kHz
Mechanical Q (Qms): 3.4
Sensitivity (dB) (1W/1M): 86
Total Loudspeaker Q (Qts): 0.62
Magnet Structure (Oz): 13.5
DEMAND:
POWERPLANT COMPONENTS = 11k (sold)
ENCOUNTER COMPONENTS = 7K
CONTACT: 0322-2240269( ALI )
