Hello mates,
Recently I placed a bet on a silly thing and lost it in the end. So as a result and as per my commitment, I am selling the whole system.
But soon, there will be a new ride and some classic new build,
The stuff I am selling is as listed.
Pioneer AVH 8450 BT (Complete Box & Accessories)
Pioneer Malaysia
Physical Condition: 10/10
Operating Condition: 10/10
[TABLE="width: 766"]
[TR]
[TD]Display[/TD]
[TD]7? WVGA[/TD]
[/TR]
[TR]
[TD]Preout (Hi-Volt)[/TD]
[TD]3 (4V)[/TD]
[/TR]
[TR]
[TD]Audio Format[/TD]
[TD]MP3, WMA, AAC[/TD]
[/TR]
[TR]
[TD]Video Format[/TD]
[TD]Mpeg1,2,4/ Divx / JPEG / WMV / H.264[/TD]
[/TR]
[TR]
[TD]AUX Input[/TD]
[TD]Rear[/TD]
[/TR]
[TR]
[TD]USB Interface[/TD]
[TD]Rear x 2 (Rear: High Current 1A Handling Capability)[/TD]
[/TR]
[TR]
[TD]Control for iPod/ iPhone (1), (2), (4)[/TD]
[TD]О (AppRadio Mode)[/TD]
[/TR]
[TR]
[TD]Bluetooth[/TD]
[TD]O[/TD]
[/TR]
[TR]
[TD]Auto EQ (3)[/TD]
[TD]О[/TD]
[/TR]
[TR]
[TD]Advanced Sound Retriever[/TD]
[TD]О[/TD]
[/TR]
[TR]
[TD]Back-Up Camera Ready[/TD]
[TD]О[/TD]
[/TR]
[TR]
[TD]SD/SDHC Memory Card Slot[/TD]
[TD]O[/TD]
[/TR]
[TR]
[TD]Dual Zone Audio/Video[/TD]
[TD]O[/TD]
[/TR]
[/TABLE]
Focal PS 165 (Complete Box & Accessories)
EISA Award 2011-2012
[TABLE="width: 588"]
[TR]
[TD]Max. power[/TD]
[TD]160 Watts[/TD]
[/TR]
[TR]
[TD]Nom. power[/TD]
[TD]80 Watts rms[/TD]
[/TR]
[TR]
[TD]Sensitivity (2.83V/1m)[/TD]
[TD]92.5dB[/TD]
[/TR]
[TR]
[TD]Frequency response (+/-3dB)[/TD]
[TD]60Hz ? 20kHz[/TD]
[/TR]
[TR]
[TD]Magnet[/TD]
[TD]85 mm[/TD]
[/TR]
[TR]
[TD]Voice coil[/TD]
[TD]1? (25mm) x 0-7/16? (11.5mm)[/TD]
[/TR]
[TR]
[TD]Tweeter[/TD]
[TD]Processed Aluminum inverted dome tweeter[/TD]
[/TR]
[TR]
[TD]Cut-out diameter[/TD]
[TD]165mm (6-1/2")[/TD]
[/TR]
[TR]
[TD]Type[/TD]
[TD]2 way kits[/TD]
[/TR]
[TR]
[TD]Diameter[/TD]
[TD]6'' 1/2[/TD]
[/TR]
[/TABLE]
Focal Polyglass 690 CVX (Complete Box & Accessories)
Eliptical coaxial drivers kits 690 CVX from Focal Car Audio speakers
[TR]
[TD]Nominal impedance[/TD]
[TD]4 Ohms[/TD]
[/TR]
[TR]
[TD]Max. power[/TD]
[TD]160W[/TD]
[/TR]
[TR]
[TD]Nom. power[/TD]
[TD]80W[/TD]
[/TR]
[TR]
[TD]93dB[/TD]
[/TR]
[TR]
[TD]50Hz-20kHz[/TD]
[/TR]
[TR]
[TD]Magnet[/TD]
[TD]85mm (3.3")[/TD]
[/TR]
[TR]
[TD]Voice coil[/TD]
[TD]25mm (1")[/TD]
[/TR]
[TR]
[TD]Tweeter[/TD]
[TD]Adjustable aluminum inverted dome tweeter[/TD]
[/TR]
[TR]
[TD]Woofer[/TD]
[TD]164x235mm (6x9")[/TD]
[/TR]
[TR]
[TD]Product type[/TD]
[TD]2-way coaxial kit[/TD]
[/TR]
[TR]
[TD]Type[/TD]
[TD]Coaxial speakers kits[/TD]
[/TR]
[TR]
[TD]Diameter[/TD]
[TD]6x9''[/TD]
[/TR]
[/TABLE]
Focal FP 4.75 Limited Edition (Complete Box & Accessories)
EMMA 2010 Award Winner
Focal FP 4.75 LE Car Audio amplifiers
Physical Condition: 09/10
[TR]
[TD]Nominal power measured at 13.8V continuously @ 4 Ohm[/TD]
[TD]4 x 75W RMS[/TD]
[/TR]
[TR]
[TD]Nominal power measured at 13.8V continuously @ 2 Ohm[/TD]
[TD]4 x 100W RMS[/TD]
[/TR]
[TR]
[TD]Power in bridged mode measured at 13.8V continuously @ 4 Ohm[/TD]
[TD]2 x 200W RMS[/TD]
[/TR]
[TR]
[TD]Signal/noise ratio[/TD]
[TD]> 100dB (A)[/TD]
[/TR]
[TR]
[TD]Damping factor at 4 Ohm[/TD]
[TD]> 200[/TD]
[/TR]
[TR]
[TD]Frequency response[/TD]
[TD]10Hz - 35kHz[/TD]
[/TR]
[TR]
[TD]Input impedance[/TD]
[TD]13 kOhms[/TD]
[/TR]
[TR]
[TD]Input sensitivity[/TD]
[TD]0.2 - 5V[/TD]
[/TR]
[TR]
[TD]High-pass filter[/TD]
[TD]50 - 150Hz (12dB/oct.)[/TD]
[/TR]
[TR]
[TD]Low-pass filter[/TD]
[/TR]
[TR]
[TD]Amplifier[/TD]
[/TR]
[TR]
[TD]Maximum cross section of loudspeaker cables[/TD]
[TD]10mm2 - 7 AWG[/TD]
[/TR]
[TR]
[TD]Maximum cross section of power cables[/TD]
[TD]25mm2 - 3 AWG[/TD]
[/TR]
[TR]
[TD]Idle current[/TD]
[TD]1A[/TD]
[/TR]
[TR]
[TD]Protections[/TD]
[TD]- Short-circuit
- Continuous power
- Thermal overload
- Soft clipping
- Overvoltage
- Polarity reversal[/TD]
[/TR]
[TR]
[TD]Dimensions ( H x W x D)[/TD]
[TD]50 x 350 x 280mm (2 x 13.75 x 11[/TD]
[/TR]
[TR]
[TD]Weight[/TD]
[TD]4.95kg (10.91Ibs)[/TD]
[/TR]
[TR]
[TD]Finish[/TD]
[TD]Brushed anodized silver gun NEW FINISH[/TD]
[/TR]
[TR]
[TD]Type[/TD]
[TD]Amplifiers[/TD]
[/TR]
[/TABLE]
Focal K2p 165 KF (Only 1 Mid Bass Driver) (Perfect for Centre Channel)
80 Rms (Without box & Crossover)
Physical Condition: 08/10
Harman Kardan Monoblock CA1500m (Complete Box & Accessories)
Harman Kardon CA1500ME Mono Amplifier | Car Audio Plus: UK In-Car Entertainment, Car CD Players, MP3 Players, Stereos
[TABLE="width: 985"]
[TR]
[TD]? ? Type : Mono sub
? Amplification : Class D
? RMS Power @ 4Ohms : 360W
? RMS Power @ 2Ohms : 600W
? RMS Power @ 1Ohm : 900W
? Electronic Crossover (Front/Rear: 12dB/Oct., Sub: 24dB/Oct.) : LP
? Variable Subsonic (12dB/Oct.) incl. EQ
? Phase Shift (Variable 0-180?)
? RJ45 Audio Input/Output
? Subwoofer Level Remote Control
? Auxiliary Line-Level Outputs (feed through)
? Multilayer boards with high-quality SMT parts and shielded transformers ensure minimum noise and distortion.
? High-current capability with high output power into low impedances guarantees perfect control of critical loads such as those from power-hungry subwoofers.
? Aluminum heatsink with casted end caps and brushed-silver aluminum inlays combines maximum heat dissipation with elegant design.
? Single-screw RCA connectors and heavy-duty power and speaker terminals for long-lasting connectivity.
? Acrylic top cover with brushed-aluminum Harman Kardon? logo; badge features blue ambient light.
? New RJ45 multichannel audio and control inputs and outputs for easy single-wire system connections.
? Variable electronic crossover networks and subsonic filters on all models[/TD]
[/TR]
[/TABLE]
Harman Kardon Infinity Kappa Perfect VQ 12? (Complete Box & Accessories
(No black listed members please
[TABLE="width: 100%"]
[TR]
[TD]Size[/TD]
[TD]12 -inch[/TD]
[/TR]
[TR]
[TD]Impedance[/TD]
[TD]4 ohms[/TD]
[/TR]
[TR]
[TD]Cone Material[/TD]
[TD]Magnesium Metal Matrix[/TD]
[/TR]
[TR]
[TD]Surround Material[/TD]
[TD]Nitrile-butylene-rubber[/TD]
[/TR]
[TR]
[TD]Ideal Sealed Box Volume (cubic feet)[/TD]
[TD]N/A[/TD]
[/TR]
[TR]
[TD]Ideal Ported Box Volume (cubic feet)[/TD]
[TD]N/A[/TD]
[/TR]
[TR]
[TD]Port diameter (inches)[/TD]
[TD]N/A[/TD]
[/TR]
[TR]
[TD]Port length (inches)[/TD]
[TD]N/A[/TD]
[/TR]
[TR]
[TD]Free-Air[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Dual Voice Coil[/TD]
[TD]No[/TD]
[/TR]
[TR]
[TD]Sensitivity[/TD]
[TD]89 dB at 1 watt [/TD]
[/TR]
[TR]
[TD]Frequency Response[/TD]
[TD]23 - 400 Hz[/TD]
[/TR]
[TR]
[TD]RMS Power Range (Watts)[/TD]
[TD]75-400[/TD]
[/TR]
[TR]
[TD]Peak Power Handling (Watts)[/TD]
[TD]1600[/TD]
[/TR]
[TR]
[TD]Top Mount Depth (inches)[/TD]
[TD]7[/TD]
[/TR]
[TR]
[TD]Bottom Mount Depth (inches)[/TD]
[TD]7 3/4[/TD]
[/TR]
[TR]
[TD]Cutout Diameter or Length (inches)[/TD]
[TD]11 1/16[/TD]
[/TR]
[TR]
[TD]Vas (liters)[/TD]
[TD]96.43[/TD]
[/TR]
[TR]
[TD]Fs (Hz)[/TD]
[TD]22.19[/TD]
[/TR]
[TR]
[TD]Qts[/TD]
[TD]0.47[/TD]
[/TR]
[TR]
[TD]Xmax (millimeters)[/TD]
[TD]16.75[/TD]
[/TR]
[/TABLE]
Pioneer D1002R 4? Coaxials (Without Box)
Pioneer TS-D1002R 4" 2-way car speakers at Crutchfield.com
[TR]
[TH="colspan: 3"]Specifications[/TH]
[/TR]
[TR]
[TD]86 dB at 1 watt [/TD]
[TD][/TD]
[/TR]
[TR]
[TD]40 - 40k Hz[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]2-25[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]110[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Impedance (Ohms)[/TD]
[TD]4[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Top-mount Depth (Inches)[/TD]
[TD]1 3/4[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Bottom-mount Depth (Inches)[/TD]
[TD]1 15/16[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]3 5/8[/TD]
[TD][/TD]
[/TR]
[/TABLE]
Focal Elite RCA?s
2 Pairs
High-performance stereo cable for amplifiers.
1x 5m extension (conductor gauge=1.5mm2 : 0.12 x 10 x 2 + aluminum core + 0.12 x 64 strands).
Boschman RCA (Silver)
1 Pair
Steering Remote
Pioneer CDSR110
Compatible With All Pioneer Units
Pioneer Iphone/ Ipod Cable (BN)
CD-IU 201S for Advanced APP Mode
AppRadioModeUSBto30-pinInterfaceCableforiPhone?4SandiPhone?
CD-IU201S - AppRadio Mode USB to 30-pin Interface Cable for iPhone? 4S and iPhone? 4 | Pioneer Electronics USA
Reverse Cam
For Pictures & Biuld Thread:
https://www.pakwheels.com/forums/car-entertainment-electronics-gps-navigation/182902-roms-sq-setup
Roms *******
SMS/ WhatsApp/ Viber Only Please
Can be Shipped to anywhere in the country on buyers expense and risk.
