Rupes LHR 21ES Big Foot Polisher (220 Volts)
Italian-bred random orbital polisher features the largest throw of any polisher available!
The Rupes LHR 21ES Big Foot Random Orbital Polisher sets the benchmark to which other random orbital polishers are compared. Rupes, a world-renowned Italian tool maker that has been manufacturing innovative power tools since 1947, set out to develop the smoothest running, most capable random orbital polisher the industry has ever seen. After years of strenuous research and development, the LHR 15ES and its big brother, the LHR 21ES Big Foot Random Orbital Polishers were born.
The Rupes LHR 21ES Big Foot Random Orbital Polisher gets its name from its massive, industry leading 21 millimeter throw. The throw of the machine indicates the size of the orbit the pad makes. Consider this: a conventional random orbital polisher has a throw between 4 and 8 millimeters. The advantage of a larger throw is that more surface area is being covered as you polish. This means you’ll be able to remove swirls, scratches, water spots and other paint defects in considerably less time. The Rupes LHR 21ES utilizes a 6 inch hook and loop backing plate designed to accommodate 7 inch pads – the perfect size for polishing horizontal and other large body panels.
The Rupes LHR 21ES Big Foot Random Orbital Polisher ensures a perfect finish with its random orbital motion and exceptionally large throw. One of the biggest advantages of the LHR 21ES is that no swirls or holograms (also referred to as buffer trails) are instilled into the paint as you polish. A conventional rotary/circular polisher, while very effective at polishing paint to remove defects, leaves swirls and holograms in the finish as a result of its direct drive, circular motion. Simply put, the Rupes LHR 21ES Big Foot Random Orbital Polisher leaves you with a perfect finish that’s free of swirls and holograms – all without the risk of burning through the paint. The Rupes LHR 21ES is so easy to use that even a novice can have the polisher mastered after only one panel!
The Rupes LHR 21ES Big Foot Random Orbital Polisher has the largest stroke of any polisher on the market. This gives the LHR 21ES a huge advantage while working on large panels because it enables you to polish a significantly larger area, reducing your overall time and increasing profits if detailing is your profession.
Next to its little brother, the LHR 15ES, the Rupes LHR 21ES Big Foot Random Orbital Polisher is the smoothest running random orbital polisher available. Like a fine Italian sports car, the Rupes LHR 21ES features remarkable engineering and exquisite craftsmanship; the ergonomics along with fit and finish on the LHR 21ES Big Foot Random Orbital Polisher are superb. The soft-start system guarantees an acceleration ramp to prevent accidental dispersion of your compound and polish while the electronic feedback control maintains constant speed in all applications. The energy-efficient 500 watt motor and massive, 21 millimeter stroke makes the Rupes LHR 21ES capable of removing up to 1500 grit sanding marks!
The Rupes LHR 21ES Big Foot Random Orbital Polisher features a variable speed dial and trigger lock that go hand-in-hand with the carefully designed body of the tool; features like this make the Rupes LHR 21ES the obvious choice for extended polishing sessions. Whether you’re a seasoned professional or someone who simply demands the best of the best, the Rupes LHR 21ES Big Foot Random Orbital Polisher will deliver.
FLEX 3401 DA Polisher (220 Volts 3-pin UK plug)
The FLEX XC 3401 Orbital Polisher is a dual action polisher on steroids! The all-weather cord resists scratches and marring of the paint as you work your way around the vehicle. The FLEX XC3401 VRG buffer effectively removes swirls, scratches, and oxidation that can't be removed using other D.A. polishers. One of our best-selling polishers just got better!
As if that weren’t impressive enough, the FLEX Orbital Polisher has shut-off carbon brushes. When the carbon brushes wear down, the motor automatically shuts off to avoid damage.
The FLEX Orbital Polisher can easily do most of the work for which you’d normally rely on a rotary machine, and it’s safer! The dual action nearly eliminates the risk of burns or holograms. Plus, the large stroke of 8 mm allows the polisher to cover more area faster. A 9 ft. power cord allows you to work easily around most vehicles.
The FLEX Orbital Polisher has an adjustable bale handle on the top and a speed control on the side for easy access with your thumb. A speed trigger on the underside of the polisher allows you to gradually accelerate speed as needed. The FLEX Orbital Polisher packs all these features into less than 6 pounds!
The FLEX XC 3401 VRG HD dual action polisher comes with a 5.5 Inch Hook & Loop Backing Plate.
Additionally, smaller backing plates are also available (4-3/8" size to allow pads from 5-6 inch sizes).
Made in Germany.
1 Year Warranty.
Jade Quartz Ceramic Ultra Premium Ceramic Coating Kit (2 Years Warranty)
Jade Quartz Ultra Premium Ceramic Coating 50ml with Foam Applicator and Microfiber Cloth
Jade Quartz is our Premium Ceramic Coating that provides unrivaled gloss and up to 2 years of durability and protection from UV rays and corrosion. It delivers better gloss, hardness, and is hydrophobic meaning it will actively repel water! Surfaces treated with Jade Ice are easier to clean and are more protected! Jade can be used on top of Urethane clear coats, gel coats, plastics, vinyl, rubber, metal, chrome and glass.
Quartz is a clear, nano crystalline coating that protects your vehicle from weather, chemicals, and UV rays while repelling water, dirt and other contaminants. Jade Ice applies a hard (7H), durable coating that is 2-3 micron thick and imparts a deep, re¬active shine. Packaged in a 50 CC bottle with a microfiber applicator.
For application guide, read this post.
Collinite Liquid Insulator Wax 845
Extreme insulation for automotive paint. available in stock
Collinite Liquid Insulator Wax was originally developed for power companies to protect against high voltage power failure, electrical fires, and explosions. If it stands up to these conditions, imagine how well it will protect your vehicle?s paint.
Collinite has been making car care products since 1912. Collinite is one of those companies whose products have been kept virtually secret outside of professional detailing and body shops, and car show circles. That?s why there is no flashy packaging and labels on Collinite products. The truth is, it?s not really necessary. Collinite products sell themselves.
Collinite Liquid Insulator Wax, for example, is one of the finest liquid carnauba waxes you can buy. It has the shine and wetness of carnauba but its longevity is more like a paint sealant. You can expect up to 5 months of protection and incredible water-beading, even on non-garaged vehicles.
Liquid Insulator Wax is in a class all its own when it comes to long-term durability, easy application, and paint enhancement. The liquid car wax was created to insulate electrical components, but it has become one of the foremost liquid car waxes on the market by word-of-mouth of Collinite?s very satisfied customers.
Liquid Insulator Wax is used on automobiles, trucks, buses and aircraft where protection is key, but frequent reapplications are not practical. The wax is excellent for fleets. It leaves a high gloss, nearly indestructible clear coating that repels water, pollution, sun, salt spray, bugs, and more.
Liquid Insulator Wax provides tough protection against adverse weather conditions. It makes a great?winter wax? when you want tough paint protection against road salt, snow and ice, without sacrificing shine. Collinite?s headquarters are in New York where harsh winters are the norm. They know a thing or two about durable paint protection.
In the summer, Insulator Wax stands up to the heat and UV rays better than most carnauba waxes. You can even use 845 on boats to guard the hull against salt water oxidation. Now that?s a tough wax!
Made in the USA.
For usage directions, please see this post.
Wolfgang Deep Gloss Paint Sealant 3.0 available in stock
Wolfgang Deep Gloss Paint Sealant 3.0 redefines the paint sealant. Also known as Last Stage Protectant LSP.
Wolfgang Deep Gloss Paint Sealant 3.0 will alter your perceptions of paint sealants forever. The glossy, liquid-like shimmer enhances all types and colors of paint. No other synthetic wax or paint sealant gives your vehicle the gloss, the depth, and the protection of Wolfgang Deep Gloss Paint Sealant 3.0. Now with fortified polymer technology, Wolfgang Deep Gloss Paint Sealant 3.0 is simply the best paint sealant you?ll ever use.
The entire Wolfgang Concours Series collection is built around this single product. Wolfgang Deep Gloss Paint Sealant 3.0 was developed in order to meet the demand for a paint protectant that captures the wet look of a carnauba wax but lasts longer. Immediately, we looked to the newest breed of crystalline ?super? polymers being developed in Germany. German Super Polymers were the foundation of our original groundbreaking formula.
Made in Germany.
Detailer's Pro Cleanse-All Exterior Cleaner
LAST PIECE
Cleans virtually every exterior surface!
The exterior of your vehicle is made up of roughly 5 or more different materials: various plastics, rubber, painted metal and/or fiberglass, and any number of polished, plated, or coated metals. You could buy cleaners for each of these surfaces, or you can buy one bottle of Detailer?s Pro Series Cleanse-All Exterior Cleaner.
This all-purpose cleaner will replace multiple products in your garage.
Detailer's Pro Series Cleanse-All Exterior Cleaner works as a:
bug & tar remover
wheel cleaner
tire cleaner
engine degreaser
convertible top cleaner
vinyl & plastic cleaner
chrome cleaner
Detailer's Pro Series Cleanse-All Exterior Cleaner can be used full strength or diluted to suit your cleaning task. This strong alkaline cleaner is powerful enough to cut through grease on engines and baked-on brake dust on roughcast aluminum wheels. Tar, sap, and bugs will break down in a matter of seconds so you can wipe your paint clean.
The only exterior surfaces that should not be cleaned by Detailer?s Pro Series Cleanse-All Exterior Cleaner are clear surfaces, including plastic lens covers, windows, and the windshield.
A car wash doesn't always cut it. To get the functional parts of your vehicle completely clean ? the engine, the wheels, the wheel wells ? you need the aggressive cleaning power of Detailer?s Pro Series Cleanse-All Exterior Cleaner. Gentle agitation allows the cleaner to pull contaminants out of porous or pitted surfaces so they rinse completely clean.
Use Detailer's Pro Series Cleanse-All Exterior Cleaner instead of a garage full of specialized cleaners. It often works better, costs less, and it certainly takes up less space in the garage!
Nanoskin AutoScrub Sponge Fine Grade
NANOSKIN AUTOSCRUB System works fast and achieves professional results with the new advanced rubber polymer technology, which replaces the use of clay bars. With either dual action orbital polisher or hand application, it safely and easily removes paint over spray, water spots, fresh tree sap, rail dust and other bonded surface contaminants from the surface of automotive paint, glass, moldings and plastic. Unlike the clay bar, the AUTOSCRUB can be cleaned by simply rinsing off the accumulated contaminates with water. If you drop the AUTOSCRUB on the ground, no worries, just rinse the sponge pad clean and you're ready to keep using it. Easy glides allows for sturdy and controlled handling, unlike clay bars where constant reshaping is required.
Features
Lasts up to 4 times longer than clay bars
For a flawless "show room perfect" shine
Glides on & off easily for a slick finish
If inadvertently dropped on floor, simply rinse clean
Sonax Wheel Cleaner Plus (acid free) available in stock
Acid-free and pH balanced, environmentally-friendly formulation
Sprays on clear, turns red as dirt and grime is penetrated
Safe for use on wheels: aluminum and alloys; painted, anodized and clear coated
30 percent Stronger than SONAX Wheel Cleaner full effect
Made in Germany
3D Orange All Purpose Cleaner Cirtus Degreaser available in stock
Orange Citrus Eco-Friendly Degreaser.
Interior / Exterior organic solvent cleaner.
Removes grease, tar, gum, bugs, adhesives, tree sap, & more.
Contains d-Limonene for safe and powerful cleaning.
Concentrated, can be diluted up to 20 to 1 with water.
Made in the USA
Available in stock
Sonax Spray Bottle 500ml Available in stock
The Sonax 500ml Spray bottle is another high quality item from SONAX. Manufactured in Germany, the spray head is fully adjustable so you can really apply products with a very fine mist or more powerful spray.
500ml Pump Sprayer
White Interior Brush Attachment
Sold Out.
This brush is meant for jobs involving rigorous scrubbing. Particularly dense rugs and st1ff carpets are ideal. The bristles are stiff enough to remove old stains and they will hold up better than the Aqua Soft Carpet Brush on heavy-duty carpet. This brush works equally well on tile, grout, and floor pads but can produce exceptional results when used with APCs, Carpet Shampoos, and similar Spot Removers.
Compatible with Porter Cable 7434, Max Shine L15 and all similar DA's with thread size of 5"/16-24.
Application Directions:
Liquid Insulator Wax can be applied by hand or using a dual action polisher equipped with a finishing pad.
If applying by hand, simply wipe on Liquid Insulator Wax using a poly foam applicator. It takes very little to cover each panel. Buff with a Cobra Microfiber Towel. This towel has excellent grip for removing waxes, and it will make application of Insulator Wax even quicker. You will find the wax easiest to remove if you apply a thin coat and do not let it completely haze over before buffing.
To apply by machine: work at a low speed with no pressure since you are simply applying a product. Use a microfiber bonnet over a lambswool pad to remove Insulator Wax. Apply wax to one section at a time, wait 30 seconds, and then buff.
This is a true wax with no cleaning properties.
If you?re looking for durability and gloss in a liquid carnauba wax, you can?t go wrong with Collinite Insulator Wax. It has been a favorite at car shows and in body shops for more than 40 years.
Directions:
Wash your vehicle using Wolfgang Auto Bathe or your favorite shampoo. Dry completely.
For the best results, use a paint cleanser like Wolfgang Paintwork Polish Enhancer to remove mild imperfections and wax build-up.
Apply Wolfgang Deep Gloss Paint Sealant 3.0 over the entire vehicle either by hand or with a machine. If applying by hand, use a yellow foam applicator. If applying by machine, use a blue finessing pad. Using a dual action polisher, set the maximum speed to 4.5 and work in overlapping sections until the entire vehicle is covered. Apply a very thin, even coat.
Once the vehicle is covered, wait 30-45 minutes before buffing off the sealant. Use a microfiber towel or a microfiber bonnet on your polisher.
This product is moisture-sensitive. In order to achieve a slick, durable finish, Wolfgang Deep Gloss Paint Sealant 3.0 must cure for at least 12 hours before being exposed to moisture. Do not apply sealant before dusk because dew will interfere with the adhesion to the paint. Park your vehicle in a garage or under a shelter while it is curing, if possible.
Use Wolfgang Deep Gloss Spritz Sealant to boost the gloss and protection any time with even more reflective Super Polymers.
Demonstration Video
Instructions
1. Use on a cool and dry wheel in a well ventilated area.
Spray on Sonax Wheel Cleaner plus holding bottle 6-8 inches from the wheel surface. Spray barrel, caliper and tire. You?ll notice the product goes on clear.
As the product begins to work and loosen the dirt and brake dust, it will change from clear to red.
Exceptionally dirty wheels may require agitation.
Allow the product to work for up to 10 minutes. If product dries, simply re-apply.
Use a high-power water source and rinse the product from the wheels. May re-apply if necessary.
Dry wheel with a clean towel or premium microfiber (Recommend Sonax 450800 Microfiber Drying Cloth).
Demonstration Video
