Hey guys i present to u my latest purchase,
Phoenix gold xenon x1200.1:
Phoenix Gold X1200.1 (x12001) - Monoblock Car Amplifier, Power Amp - Sonic Electronix
nice purchase! Congrats bro!
ahan good..
congrats man... this amp is hungry for volts...make sure you feed it with atlest 4 awg wire (advised are 2x 4 awg wires along with a cap). Dont expect it to preform well on a 6 awg wire
Sir its better to add a battery rather then a capacitor. In my SPL5000 setup I have 120A alternator 85A Battery and 65A battery. Voltage remains between 13~13.2Volts and I am using stinger 4AWG wiring.
congratzz smartboy finally u bought it...
now do give me ur car demo soon !!
congrates bro!
good dear
smarty congraaaaats a ton on this beauty. excellent
i have a suggestion though
run ur type R pair at 4ohms not 1ohms, ull be surprised with the accuracy n definition i tell u. Notes will be much sharper
as its 1200rms on 4ohms aswell waoooooooo XD
Sir, the manufacturer advises, in the manual to add a cap, but if you like batteries rather than caps its up to you
YAY!!! the SQ revolution has started. Congratulations on such a fine purchase
Congrats...!
i tried a 2 farad cap on my setup. no difference at all.i would suggest u get urself a 120A alt.
my setup sounded 30% louder when i changed from my stock alt to 120A.
also try to wire this amp on 4 ohms load rather thern 1 ohms. mayb there will be some difference . do try it . i couldnt because i was using a 2 ohms config.
this amp is a beauty. congrats smarty. now ur type Rs will bang really hard for sure
clean 1200rms ...from 4ohms all the way to 1ohm. lovely.
i think kevin had this amp??
congrats dude..
nyce purchase ali....
Conragts!
Congrats Brother. Did you get a test certificate with it? want to know the actual benched power of this beast.
no we dont have the certificate. but from wat we have tested, it is much better then magus and almost identical to solid audio 15d. but this amp has a plus point being equal on all ohms load and is branded by PG
congratz brother
