The thing is like this:
First the system:
Headunit:JVC KW-xc899
Amp:pioneer pa-950
Speakers:Pair at back of Kenwood KFC 6960 ie and 2 factory fitted stocks of coure
Woofer:Sony Xplod XS-L124P5R
Rear kenwoods and woofer is being used on the same amp as its four channel and the frnt speakers are direct with the headunit.
Problem:I was standing at line for cng and i got a feeling of something burning but ignored it, then after some time whnever high basss was there the system got off because the battery was going low as the car was off but after some time it completely switched off and the battery was dead and after getting the gas filled i pushed the car to mechanics who started the car and i went on with the system at high volume,i again smelt burning smell but was ignoring it as i was thinkin it was coming from outside but then as i moved i could seee smoke which firstly i think was dust but smell was also there and i suddenly switched off the car and the smoke stoopped in abt 5 secs and then i looked under the seat,the terminal where we plug the ground wire, the plastic on the side was burning so i unplugged the amp completely as i was having screw driver luckily.And came home with it,
So i want to know what could be the cause of problem as i want to plug it again.
Thanks in advance
