Boschmann Amp, 2 channel700 watt
Pioneer Sub Woofer 15",600 watt
Both are first hand and are NOT Repaired! Still running in my car....
Demand 8k, slightly negotiable
sounds good, please post pics...thanks
Sub Woofer box and front grill is not included and neither is the wiring b.t.w
new woofer comes in range 2800-3400 Rs 700 watts AMp in 5500Rs-8000 Rs
so i dont see any benefit in this deal and also this boschmann is all frills but no sound quality
@kkooolit is not a 12" woofer first of all. its a 15" model.secondly the amp is not chinese or crappy. its branded stuffhttp://www.boschmann.com/images/main.html
@hash4u
sorry dude
but then again now we know the specs more than u said
yar i hav seen B.,M woofer of 12"(BASS METAL) and that guy was demanding just 1700 for that .it was unrepaired working in his car
hash: i am also planning an amp and woofer in car.. but its not in my this month's budget
intrested in selling just the amp? because i just need amp i've a 12" woofer.what's the asking price tag with amp?
Hashim Bhai, im interested in ur amp ... ihave 2 kenwood 12" KFC 3005 subs with 700PMPO and 175RMS, can i run those with ur amp?
@GtiRfor 2 subs you will be needing a 4 channel amplifier. Mine is 2 channel.
@carzcrazyi have posted the specs and even pictures but still i get stupid questions to answer to The woofer i am selling is 15 inches not 12inches. make is pioneer not bauschmann! if u get cheaper in market please go ahead
Why are u sellin it......sorry for the stupid question....
going for a 1000 watt sub and a 1500 watt amp
@ hash and GTiR
i dont know what hash means by u need 4 channels, if u have 2 subs, run them thru 2 channels, in steroe or in mono, as u like,
y the other 2 channels
@RedBull_ar
The amp skips....or say stops for a while when u run 2 subs on a 2 channel....Did it myself.
The amps having 4/3/2 option means it can run on 4 Channel (4 Speakers), 3 Channel (1 Woofer & 2 Speakers) and 2 Channel (2 Woofers). Another important issue is the impendance, if we put two woofers (1/R=1/R1 + 1/R2+... rule) it will double the load on the amp causing excessive heat dissipation and the amp turns into the protection mode. So never try to overload the amp otherwise you might not enjoy the real power of amp facing more distortion levels...
@untitled wateri think u r refering to clipingnumber of channels does not have to do with amp power compatiblityrunning 2 channels on a 2 ch or 4 ch amp would require same amount of power from power amp section. number of channels does not dictate power outputif the amp is branded and it says it can handle 2 low impedance loads than it should handle it.
@ testdriverby parralel connection (1/R rule) u reduce the load hence the high current
reduction in load resistance puts much strain on the amps. Think of when you short circuit the +ve and -ve terminals directly (means a very little resistance of wire), the amp will shut off.....
As far as the channel are concerned, keep in mind that for each channel there is a separate amplification circuitry, so in a 2 channel amp, there are two redundant circuits and like-wise 4 channel consists of 4 circuits...
@ test driver saab
itna to muje bhi pata hai i was correcting u
as far as heating is concerned, its mostly related to power supply which in most cases is common
