I m having a dellson 6inch lvd/dvd player installed in toyota belta its navigation option dosent open...and it has a gps antenna on its dash board dont know how does it workx...cant fine its fitting
brother... alone gps and gps antenna will not work until you have the correct maps.. make sure you have the map on the memory card and the memory card inserted into the player. because alone the gps will only be able to get the co-ordinates but to point them correctly it requires the map..
Hmm but even when i inserts the maps on sd card in the player the navigation option dosent open:/...
take it to the guy u bought it from. he'll fix it for you. waisay there are usually two sd slots on some models. one for map sd card and other for media. are you sure u r inserting it into correct slot? and are you sure the maps are correct? where did u get the maps from?
well there r 2 sd card slots but 1 ov them ix fixed....nd i put samples ov all sorts ov maps,,,with diffrent formats....and the guy from whom i bought it, iz asking minimun 9k for navigation...
thats the thing. if u get maps of ur own, they might not work with these units. u have to have maps designed for these units for them to work properly
