not all cars or civics use two bulbs for high and low beam separately. civics until 2000 had only a single bulb with both hi/low built in. the new ones are different...
my suggestion is that you put the HIDs in your low beam and not your high....cuz chances are that your head lamps are not projector based. non projector head lamps are not designed for HIDs at all....as a result...they produce too much glare.
i dont know about the type of hids in pakistan but here...if u get an H4 HID setup...you loose your high beam..lol...the low beam HID is enough to do the shyt...
