The next upgrade is my subwoofer. This particular subwoofer was always on my wishlist and I always dreamed of owning and testing this particular subwoofer one day. After testing and owning close to a dozen subwoofers, I have had a fair experience of what a good sub sounds like. The wish came true and I now have the chance to own this subwoofer. The subwoofer itself represents the highest level of car audio fidelity. The brand power itself ranks among the top high-end audiophile grade ones. The persona, quality and the representation of the subwoofer tells a tale of its own. The craftsmanship involved in the design, technology, appearance and performance is unparalleled. The subwoofer is handcrafted in Germany, the subwoofer itself comes shipped in a wooden crate box tagged with its own unique serial number. The subwoofer is from the flagship series of a high-end brand audio brand. So here is my next upgrade..
BRAX MATRIX 10.1 by Audiotech Fischer
Puristic, Powerful, Consistent
From now on, the high-end-Subwoofer BRAX MATRIX 10.1 is the synonym for boundless bass response and an absolute top-class sound experience. As the result of a long lasting development process, this audiophile masterpiece uncompromisingly unites all elements of Audiotec Fischer's ambitious corporate philosophy.
The best and finest materials and components are barely good enough for the Subwoofer BRAX MATRIX 10.1. The hand-scooped cone has a great stiffness and is still amazingly light. The physical characteristics of the selected materials sisal and aluminium oxide contribute to an ideal combination of low weight and excellent mechanical qualities of the cone. The rubber surround and the highly insulating eddy-current-free voice coil, both especially designed for BRAX MATRIX 10.1, account for exceeding load with enormous flexibility. Massive strokes and bass sounds from the deepest abyss are guaranteed.
Finally, all of the subwoofer's parameters were perfectly harmonized. From the specifically designed diecast basket to the flawless terminals, everything is simply marvellous. Below the line, the Subwoofer BRAX MATRIX 10.1 excels with most precise, clear and voluminous bass rendition, both at low and extremely high sound levels. However, with the subwoofer,s puristic but technically and visually mature design Audiotec Fischer only aims at one goal:
The creation of a perfect woofer, of course "made in Germany"
Specifications:
Power handling RMS / Max: 600 / 1200 Watts
Impedance: 4 Ohms
Voice coil diameter: 65 mm
Voice coil winding height: 33 mm
Resonance frequency: 38 Hz
Mechanical Q factor: 10.30
[B]Electrical Q factor: [/B]0.59[B]
Total Q factor: [/B]0.56[B][B]
[B]Efficiency 1 W / 1 m:[/B][/B][/B] 87 dB[B][B][B]
Outer diameter: [/B][/B][/B]275 mm / 10.83“[B][B][B][B]
[B]Cutout diameter: [/B][/B][/B][/B][/B]235 mm / 9.25“[B][B][B][B][B]
Mounting depth: [/B][/B][/B][/B][/B]114 mm / 4.49“[B][B][B][B][B][B][B]
Recommended enclosure: [/B][/B][/B][/B][/B][/B][/B]Sealed box 28 L[B][B][B][B][B][B][B]
[/B][/B][/B][/B][/B][/B][/B][TABLE]
<tbody>[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
</tbody>[/TABLE]
Source: BRAX MATRIX 10.1
Hope you like it
