@naveed
actually CNG needs less air to burn and petrol needs more
son in terms on CNG u need less air from yr intake pipe
now their is differance ..as yr car is carb engine and other fe are efi.....efi to be correct you have to block some air
but in carb engine as yr is....some ppl do block and some ppl dont.....but as i am also using a carb 1000cc khyber engine
blocking or not blocking does not effect on yr fuel economy on GAS..but it do effect some performance when you rev it hard
i am getting same fuel economy with or without blocking the pipe even with cold intake i got the same fueleconomy which is almost 140km in 380 full tank
